WTB: Polk DSW Pro 400 or HSU VTF-2 MK2 or MK3
jmwest1970
jmwest1970 Posts: 846
edited January 2009 in Wanted (WTB) Classifieds
I just missed a deal today on a HSU VTF-2 MK2 for $250, but such is life.
My POS JBL sub is dying and I'm looking for something decent to replace it. I've narrowed it down to these models so if you have one or know where to grab one please let me know.
Post edited by jmwest1970 on
    treitz3 Posts: 19,195
    edited March 2008
    Allow me to interrupt please. What's wrong with the JBL sub? If you are pleased with it, would it not be cost effective to try to repair that one?
    If not, try to get a DSW. They are still relatively new, so a used one may be hard to come across but ya' never know...
  • jmwest1970
    edited March 2008
    treitz3 wrote: »
    The sub is a JBL PB12 and is "chirping" when turned on and intermittently during operation. The research I've done is that it uses a proprietary amp that has no parts available and the woofer is a 2 ohm sub so common plate amps won't work.
    treitz3 wrote: »
    I've found a DSW Pro 400 at At Your Service Electronics
    for $278, but I'm not inclined to buy it there as I don't see them on the Authorized Online Dealers list.
  • jmwest1970
    edited January 2009
    I'm still looking to replace the JBL. Anyone looking to part with a DSW400 or DSW500?
  • ViperZ
    ViperZ Posts: 2,046
    edited January 2009
    jmwest1970 wrote: »
    I have a lot of experience repairing the PB12 in particular. If the serial number of yours starts with 'AM', then it's an older model and it uses a proprietary amplifier module (basically, it's a "normal" amplifier, but encapsulated in epoxy, so it does not get enough heat dissipated from the transistors). Replacing that amp module will usually cost around 150 dollars and will last 6-12 months.
    If your serial number stars with 'HA', then it's the newer model, there is no proprietary amplifier (just discrete parts), and the amp is definitely repairable.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • jmwest1970
    edited January 2009
    ViperZ wrote: »
    I took a look at it's an HA. Is the amp replaceable, or is repair the best route to take? Also, what's your opinion on this sub?
  • ViperZ
    ViperZ Posts: 2,046
    edited January 2009
    jmwest1970 wrote: »
    The amp is definitely repairable. Check the Harman/JBL site for local repair sites. In Canada, JAM Industries does most of the repairs.
    PB12 was one of my first "real" subs. Since then I moved to dual JBL Studio S120PII, then to dual Velodyne DPS-12. Now I have a single NHT SubTwo in one setup, and single Velodyne ULD-15 in another.
    After going through several subs, I definitely think that this sub is good only for the home theater, but not for music. It's loud enough for the explosions, but otherwise, it won't cover music well at all. I don't want to say that it's boomy, but it does not differentiate well between different low frequencies. I guess, I am too spoiled now with the sealed servo subs.
    In the price range for that sub, if you want to stay with JBL line-up, I'd look at JBL S120PII (you can even get new ones on ebay) or whatever replaced it. S120PII is a ported forward-firing 450W RMS sub and was pretty good even for music.
    The amplifiers in the Studio series are much much better in terms of performance and build (heat dissipation).
    B&W CDM1-SE fronts
    B&W CDM-CNT center
