Can anyone tell me if the speaker is Reference Monitor 7 Speakers?
roppy
It has 1 tweeter, 2 midrange and 1 subwoofer. They also have a stand for each.
I need a new subwoofer and also what is the frequency rate.
Post edited by roppy on
Pictures are worth a thousand words.
But they are most likely Monitor 10's.
ScottI like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
I have never heard of the Reference Monitor 7. However, I have heard of the Monitor 7 for a while back, and if it has two mid ranges it's certainly not it. The Monitor 7 of vintage past only has one mid range and doesn't have a subwoofer, but a passive radiator. I don't think they came with stands either.
It sounds like you have a pair of Monitor 10's which did indeed have 2 mid ranges. Are they located side-by-side, as in a horizontal orientation? Or are they vertically aligned? They also came with stands, so odds are pretty good that's what they are.
Pics would help.Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II -
Thanks guy’s for you quick response. I have the serial # in the back and they are 10s..I have a picture but could not figure out how to put it up. Next question. Do you what kind of fuse I have to get. Also I need a new subwoofer. Do you think Polk will have in stock? Thanks for your help.
Thanks guys for you quick response. I have the serial # in the back and they are 10s..I have a picture but could not figure out how to put it up. Next question. Do you what kind of fuse I have to get. Also I need a new subwoofer. Do you think Polk will have in stock? Thanks for your help.
The 10's don't have subwoofers, they have passive radiators. Depending what's wrong with it, you might be able to fix it. I'm fairly sure Polk doesn't have any replacements for them.Lovin that music year after year.
Polk SDA-1B,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
Computer Rig
Polk SDA CRS+,
OK..How do you fix it..Can I do my self?
What's wrong with it?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I am not getting any sound out of it.
It's a "passive" radiator. http://en.wikipedia.org/wiki/Passive_radiator_(speaker)"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks for the info…that was really confusing to understand…maybe it is not the radiator. I will get back to you…Would you know what type of fuse I need by the speaker connections?
1A 250v.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
