Is it (safe) ok?
carversound
I have two 1.5ts
first 1.5t
pre amp left output to amp left input, amp left output to left speaker
second 1.5t
pre amp right output to amp right input, amp right output to right speaker
One channel on each amp nothing hooked up
Is this ok to do?
first 1.5t
second 1.5t
Is this ok to do?
Post edited by carversound on
Yes but why?
engtazengtaz
I just want to use both. I have 2 outputs (c-2) Could I run both rights to one amp and both lefts to other amp.
Then run two sets of wire to one speaker, and 2 sets to other speaker,the speakers only have 1 connect 1+ 1- -
Is the 1.5 able to do mono?? Mono or the way you want to do it is fine as long as you are not using SDA's.
engtazengtaz
engtaz
no mono
I put two ways to hook up will both work ? -
Are your speakers able to be bi-amped?
engtazengtaz
no there not
but could I still run two sets of wire? -
Actually rereading your writeup, No you should not tie the amps outputs together.
engtazengtaz
so the first way would be ok?
Yes but kind of a waste? Time for some new speakers that are bi-amped. LOL:D
engtazengtaz
Ya I know there coming in june
Just want to use both amps -
I understand. I wish I had your problem.
engtazengtaz
As you can tell by the set up i am running 2 also currently bi-amping the RTi12s. The ony way you can do what your trying is to send your carvers out to be modified by one of the carver specialty groups sp they can be briged.If life had more tubes it would be a lot smoother.
yes it is okay
