Copying My SACD's ....
AudioFilet
AudioFilet Posts: 235
edited March 2008 in Electronics
A while back I bought a digital recorder, Zoom model H4. I bought it mainly for taking to shows and recording a friend's band and making a demo. It does an outstanding job of that, and sound quality is outstanding. It has 3 selections for recording:
44.1khz @ either 16 0r 24 bit
48khz @ either 16 or 24 bit
98khz @ either 16 or 24 bit
I can use the line inputs on the thing, connected to my preamp to record the SACD's
I realize that I would need to record at 44.1 & 16 bit to get this on to a standard CD. My question is whether or not that is sufficient to provide any benefit there when copying SACD's to redbook CD's.
Would there be any benefit to recording at the higher resoloution and converting?
At the very least, I should be able to get SACD quality recordings on my hard drive at least??
I am also thinking that this might be a good way to copy vinyl as well??
What do you guys think anout all this?
2 Channel rig:
LSi9"s (modified xover's) & HSU Sub
Harman Kardon HK 990 Amp
Onkyo C-S5VL SACD
Music Hall MMF 5.1
Furman Elite 15
HT rig:
HK AVR-745 & Polk Monitor Series
Post edited by AudioFilet on
  • AudioFilet
    edited March 2008
    Is this one just too absurd for consideration?
    2 Channel rig:
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
  • ben62670
    ben62670 Posts: 15,969
    edited March 2008
    Actually no. I know a person who has one of those, and the recordings are phenomenal. In a good room, and with real good equipment the possibility of getting a great recording it there for sure.
    Ben
  • Systems
    Systems Posts: 14,872
    edited March 2008
    Keiko wrote: »
    To my knowledge there is no way to copy the hi-def SACD layer.
    He will be using the line outs so he will be making an analog copy,not a direct digital copy which as you note is not doable.
    Testing
    Testing
    Testing
  • AudioFilet
    edited March 2008
    GV#27 wrote: »
    Yes, I am using the line-out connections. I have an adapter cable for the purpose.
    2 Channel rig:
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
  • shack
    shack Posts: 11,154
    edited March 2008
    Yes...SACD was designed with copy protection in mind. You will not be able to get the anywhere near the resoulution to reap the benefits. Not even on your HD.
  • madmax
    madmax Posts: 12,434
    edited March 2008
    You are recording, not copying. And yes, I believe you will have a recording which is very close to the SACD output analog outputs. I doubt we could tell a difference. Same with recording LP.
    madmax
    Edit: I am refering to recording at higher resolutions than CD.
    Vinyl, the final frontier...
  • Systems
    edited March 2008
    madmax wrote: »
    Maybe, maybe not.The signal will be subjected to more processing,a stage of analog to digital conversion at the input of the recorder then another stage of Dto A conversion at its outputs if using the analog outs.
    Testing
    Testing
    Testing
  • AudioFilet
    edited March 2008
    I don't think there would be too much additional processing. The signal comes straight from the preamp record outputs right to the recorder.
    2 Channel rig:
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
  • Systems
    edited March 2008
    AudioFilet wrote: »
    The additional steps of processing take place in the recorder.
    Testing
    Testing
    Testing
  • madmax
    edited March 2008
    Yes, it certainly goes through an A-D, gets stored then through the D-A when played back. It all depends on the quality of the recorder as to what it sounds like. It should be really good though.
    madmax
  • AudioFilet
    edited March 2008
    I will know soon, I am doing one now. The SACD is Keb' Mo', The Door. I chose that one because it is a very well done recording, and I also have the standard redbook CD as well. This way I can make some direct comparasons, hopefully with some positive results
    2 Channel rig:
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
  • furball
    furball Posts: 234
    edited March 2008
    You are going through 2 unnecessary intermediary steps, D/A conversion, then A/D conversion. There is bound to be some quality loss. The quality loss may not be audible, but it is definitely there.
    Don't SACD's come with a CD layer as well? Why can't you just copy that CD layer?
  • furball
    furball Posts: 234
    edited March 2008
    A while back someone came up with a way to digitally copy DVD Audio (the other HD audio standard) discs. But the volume of data takes up way too much hard disk space, and it is slow.
  • AudioFilet
    edited March 2008
    Not all SACD's are dual-layer (hybrid). The only to way copy the SACD layer is through the analog outputs. The idea here is to use the SACD layer to produce a copy that is superior to the standard redbook CD. Some quality loss is to be expected due to the methods that have to be used.
    My first attempt was OK, but I need to do it over due to some problems with the preamp and incorrect level settings on the recorder. This time I will run everything through my Outlaw RR2150. The recorder is new to me, so I am still geting familiar with it.
    2 Channel rig:
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
  • furball
    furball Posts: 234
    edited March 2008
    Have you thought about purchasing a professional ADC for the job? It'll probably give you much better results.
  • AudioFilet
    edited March 2008
    What is an ADC??
    The recorder only cost me about $300, and can be used for all sorts of other fun stuff. I only do this stuff for fun.
    2 Channel rig:
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
  • Refefer
    Refefer Posts: 1,280
    edited March 2008
    hmm. Would it be possible to have a player decode the disc and send the signal into a computer via it's optical/spid in? That way you could get an (hopefully) digitally identical copy.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • AudioFilet
    edited March 2008
    SACD players are engineered to output only to the analogs when playing SACD. There is no such animal as an SACD computer drive. This is why the format is almost dead.
    2 Channel rig:
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
  • furball
    furball Posts: 234
    edited March 2008
    SACD's wont output digital output, the signal only outputs to the analog out.
    DAC stands for digital audio converter. ADC stands for analog digital converter. You already have an ADC. I was just wondering if you use a higher grade ADC you can get better results.
    Benchmark makes an amazing DAC (Benchmark DAC1). Benchmark also makes an outstand ADC.
