Quick driver replacement question!
audiobliss
audiobliss Posts: 12,518
edited March 2008 in Car Audio & Electronics
Ok, so my friend has a 1997 BMW 318i, and the front 'bass' drivers are blown. He pulled them out today, and now we're looking for some replacement drivers. Well, they're 130mm (5.11") drivers, so I've been looking for 5.25" drivers to replace them with.
The stock drivers are Nokia LPT 130's. Here they are in an ebay ad. They handle 40watts and, of course, are 4ohm.
Well, any 5.25" inch 4ohm (car audio) speakers I can find on CC, BB, WalMart, or Radio Shack's website are 2-ways. I'm not sure what the rest of the stock BMW system consists of, but it already has the higher ranges taken care of and we're just interested in cheaply replacing these drivers.
So, I turned to PartsExpress. Same deal with their car audio speakers. However, any reason why their 5.25" woofers wouldn't do the job just as well?
Found a great 5.25" woofer, 4ohm, 30watt power handling, for only $18.50; sweet, meets all the requirements! Now, I can understand that it might not withstand the rigors of the moisture and temperature differences seen in a car environment as well as a car speaker would, but it should still last a while, and I'm thinking why not go for it.
Here it is:
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=295-302
What do you think? Know of any better ideas?
Thanks!
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Post edited by audiobliss on
  • eloplayspolo
    eloplayspolo Posts: 1,117
    edited March 2008
    yeah, throw in a 125x4 alpine PDX amp and bi amp them with some SR Components.
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • audiobliss
    edited March 2008
    Yeah, that'd be awesome. Please actually read the post and address the issue at hand next time.
    Or, add a smiley if you're not serious, so it'll be more obvious.
    Thanks. :)
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • MacLeod
    MacLeod Posts: 14,358
    edited March 2008
    Looks a little beefy. May not fit in the stock spot.
    If youre just wanting a simply drop in replacement tho it would work if it will fit.
    Try looking around Madisound.com as well.
  • exalted512
    exalted512 Posts: 10,735
    edited March 2008
    While reading this post, that was actually the exact driver I was going to refer you to. Does the beamer not have the plastic housing behind the speaker? You just want to avoid direct water contact, which if it has the plastic housing, it would serve that purpose. If not:
    http://cgi.ebay.com/XTC-5-1-4-Acoustic-Speaker-Baffles-VXT55-ONE-PAIR_W0QQitemZ290187117420QQihZ019QQcategoryZ50552QQrdZ1QQssPageNameZWD1VQQ_trksidZp1638.m118.l1247QQcmdZViewItem
    but cut out the bottom, as they would make for a horrible enclosure.
    -Cody
  • eloplayspolo
    edited March 2008
    sorry, ha here :)
    2013 Toyota Prius
    Mosconi 6to8 v8
  • audiobliss
    edited March 2008
    Thanks for all the info. He's going to measure the depth to make sure, as eyeballing it, it looks like it'll be really close. I'll have him check out how well that area is isolated and try to talk him into buying those foam isolators.
    Thanks!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
