DVD / Receiver Hook-up
ricogirly
So I have what may be an incredibly basic & dumb question. But I'm gonna ask anyway. So I purchased onkyo sr605 and was attempting to hook it up yesterday... and was having problem with the audio coming out of the speakers (rm6750) . But my question is, the dvd player has the coaxial cable going to the receiver as well as the hdmi going to the receiver. So from the receiver to the tv all i need is the HDMI only right? Do i need an optical cable or coaxial goin from the receiver to the tv also?
eventually i'll figure it out.. but i was gonna go buy cables in a bit and wasnt sure
Post edited by ricogirly on
Welcome to CP
You need HDMI going to TV only.
As far as DVD player and reciever is concerned, you can transmit audio using either HDMI oe Coaxical. Just make sure you have same settings on both sides, i-e if DVD is sending audio via HDMI then receiver should be configured to receiver it via HDMI, In this case you don't need coaxial cable.-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
thanks for your response! i appreciate it.
Also, TV's don't have optical or coax digital inputs usually. If they have the connections, that is for the 5.1 digital output because of the built in ATSC digital tuner.Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
