TV calaboration help
tecmo04
tecmo04 Posts: 421
For starters, im to lazy to go buy avia.
When watching sports it seems like my tv cant keep up some times. i know it should be able to. Also, the wood on the basketball court isnt as crisp as id like it to be. Its almost like theres a theres a film over it, it get a little blurry. Any advise on which setting would fix this? i.e. picture, brightness, sharpness, color...
Post edited by tecmo04 on
  • Montoya
    Montoya Posts: 506
    edited March 2008
    Have you tried THX video calibration? If you have noise reduction on you might want to turn it off if you have a good cable/sat signal. THX calibration is available on many DVD's as a menu option.
