Question about tweeters and speaker wiring.
SolidSqual
The tweeter on my Emmy's is exposed in the back. I'm wondering if I fabricated the proper connections, could I attach my signal speaker wire to the positive and negative on the back of the tweeter? From what I can tell this is basically what is done right now, except a wire is run from the tweeter to the binding posts at the bass of the speaker.
I figure better wire attached directly to the tweeter and the lack of a binding post should yield even better sound. This is something I want to experiment with once I get everything broken in, but I don't want to blow my speaker up.
Mike
Mike
Post edited by SolidSqual on
Just as long as you don't over power them, you shouldn't have a problem.
No XO, and straight to a tweeter? I think it would blow.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I think he is just trying to put better wire to the tweeter by replacing the factory wire, not bypassing the XO. I am not an expert, but whatever wire came from the factory had a certain guage, metal type and wind, and inductance for that speaker, you may not want to mess with it. I would be careful as to not void the warranty...
Venom
