WooHoo, new laptop!
madmax
madmax Posts: 12,434
edited April 2008 in Electronics
So, what do you do when you want to upgrade your laptop but can't afford or want the best ones out there? I picked this mid line Dell. Seemed like a good price at $699 and seems to work very well. It was on sale last week (and will probably be cheaper next week...) so I picked one up.
http://www.bestbuy.com/site/olspage.jsp?skuId=8679049&st=1526&lp=1&type=product&cp=1&id=1197678601495
I'm not very "in the know" about this stuff. Did I do ok, so so, or took a beating?
madmax
Vinyl, the final frontier...
Post edited by madmax on
  • bobman1235
    bobman1235 Posts: 10,822
    edited March 2008
    Looks decent, though I don't know why you'd go through BestBuy to buy a Dell when you can get them directly from Dell.
    I have a low-end Dell (an Inspiron 1501 with similar specs, paid like 550 for it 9 months ago or so) and have been extremely happy with it for what I paid.
  • madmax
    edited March 2008
    bobman1235 wrote: »
    I was there looking around and some sales guy said "hey, we have a great deal on a dell, only one left, do you want it" so I said yes. My research was non-existent on this purchase. I normally dont do that but I guess I was looking for something to play with.
    madmax
  • the7comeback7ki
    the7comeback7ki Posts: 51
    edited March 2008
    looks like a good pick up for the price. Not familiar with the x-2's that much since I have a core 2 duo in my laptop. Looks like you got 200 off? Not bad. Much better than what 699 would get you otherwise I am sure.
  • SKsolutions
    SKsolutions Posts: 1,820
    edited March 2008
    Good deal IMO. I have the Turion64 X2 in this HP notebook, and it's cool and very quick. Battery time is pretty good. The newer Intel's are more efficient, but if you aren't looking for max battery time, the X2 is a great buy, and reliable. For some graphic files, it's quicker than the intel. It will do a true 64bit OS if you have the desire to play with that as well.
    Good value.
    -Ignorance is strength -
  • madmax
    edited March 2008
    I just thought I would mention that after being on this laptop for a week straight (work and home) I find it to be AWESOME! A lot of the eye strain I was experiencing on the older Dell I had went away. This one is just so easy to look at. I'm actually glad the old one started malfunctioning at this point. I didn't realize the LCD could be this much better. I'm liking vista as well. The only negative thing I can say about it is the speakers leave a lot to be desired. They work and all but are not very loud or of any real quality.
    madmax
  • Early B.
    Early B. Posts: 7,900
    edited March 2008
    Yep. You got a great deal. Glad to see it's working out for you.
    "God grooves with tubes."
  • SKsolutions
    edited March 2008
    Turn the screen up all the way, then back it off a notch or two. You'll get less eyestrain, and the bulbs and inverter will last a lot longer. Dell is putting out a good product, and there's nothing like a new uncluttered laptop. Get a cheap set of cans for the road if the speaks suck:)
  • eloplayspolo
    eloplayspolo Posts: 1,117
    edited March 2008
    To all people on this forum... if u plan to buy a laptop or a computer or even any electronic at all... check costco first. i got a $1900 laptop for 1149.. costco has its very own product models, usualy a tiny dif from a product say circuit city and bestbuy carry... but wayyyyy less. walmart and sams club are also good.
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • madmax
    edited March 2008
    I agree. I normally look at sams club, don't have a membership at costco. New egg, tiger direct and some others always provide some interesting options too.
  • danger boy
    danger boy Posts: 15,722
    edited March 2008
    I got basically the same laptop as you did madmax for about the same price. i like mine too. it's a fast little bugger with that duo core processor.
    PolkFest 2012, who's going>?
  • clubvikram
    clubvikram Posts: 27
    edited April 2008
    Dell is good, i slao have been using its inspirra brand iam quite satissfied with it
