Help, please.
RK8
RK8 Posts: 9
edited March 2008 in Speakers
I recently got a Polk csi3 center from a friend that needed $100, new in box.
So then I bought 2 r50's from Fry's for $120/pr, and 4 r150's for $100.
I added a Klipsch KSW10 subwoofer for $150. I think these were good deals, but not sure.
Do these match well for a starter Home Theater system? Any recommendations for a 7.1 receiver? I was looking at a Marantz 7500, but am fairly clueless.
How many watts do I need?
Thank you very much for any help you can give me.
Post edited by RK8 on
  • ben62670
    ben62670 Posts: 15,969
    edited March 2008
    I personally like HK, but the Marantz will be fine. Just make sure it has Pre outs. Don't get too hung up on watts. With HK 45 is fine. Others I recommend around 100wpc. Your off to a good start. I don't really like Klipsch. Other will chime in.
    Welcome to CP
    Ben
    Ben
  • Refefer
    Refefer Posts: 1,280
    edited March 2008
    It sounds like a good entry level system. Certainly better than almost all HTiBs, so your off to a good start. I second ben's statement about pre-outs, and not to get too obsessed with power. If you need more power later, that's what the pre-outs are for. As for the sub, someday you might want more bang but for now it looks like you're good.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • the7comeback7ki
    the7comeback7ki Posts: 51
    edited March 2008
    I started(still using) the same setup but in 5.1. It sounds great over here .
    Edit: differant subwoofer. Same speakers
  • RK8
    RK8 Posts: 9
    edited March 2008
    Thank you all. The sub is from Costco and could be taken back (still in box).
    Is the Polk one better?
    Sorry for ignorance, but what is pre-out?
  • Refefer
    edited March 2008
    RK8 wrote: »
    Pre-outs, aka Preamp-outs, allows you to use the receiver as a preamp. In case you're not familiar with preamps, they are devices which allow you to control all sound processing (volume control, tone controls, signal processing such as Dolby and others) and then send the resulting signal to an external amplifier. It's a very convenient feature to have since it allows you to buy an external amplifier, which can be extremely powerful, without having to buy a preamp at the same time.
    Polk SDA-1B,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    Computer Rig
    Polk SDA CRS+,
  • cfrizz
    cfrizz Posts: 13,415
    edited March 2008
    Welcome RK.
    If you click on this link, and click on the other link for a picture of the back
    http://us.marantz.com/Products/2086.asp?ProductName=SR6001+XM+Ready+Surround+Sound+Receiver+#
    you will see on the right hand side a box that is labeled Preout. This is for hooking up a separate amplifier for more power than your receiver will ever be able to give your speakers. It makes a big difference on how good everything sounds.
    These receivers cost more money but having that feature is essential for future upgrades in power.
    From what I have read, the new Polk DSW subs are terrific & well worth getting.
  • RK8
    RK8 Posts: 9
    edited March 2008
    Thank you all for your help. I think I may return the Klipsch sub and get a Polk, will the psw10 go well with the R50's and CSI3?
    One more, if you will:
    Any recommendations on these?
    Harmon Kardon AVR-247 50 watts (x7) $399 (free shipping too)
    Onkyo TX-SR605 90 watts (x7) $399
    Pioneer VSX 1017TXVK 150 watts(x7) $359
    Marantz SR4002 80 watts9x7) $419 (THX certified)
    Please briefly school me on importance, or lack thereof, of wattage.
    Is THXcertification a big deal?
    Thank you all in advance.
  • danger boy
    danger boy Posts: 15,722
    edited March 2008
    RK8 wrote: »
    of those 4 receivers, i'd go for the Marantz. Yeah 80 watts don't seem like much.. but like HK, i have found that they under rate their power by a little bit. It should drive your speakers fine.
    PolkFest 2012, who's going>?
  • ben62670
    edited March 2008
    No need for a new thread I would keep it here...
    I like the HK's. For the money, and pre-outs you can't beat the bang for buck.
    http://stores.ebay.com/Harman-Audio_...QQftidZ1QQtZkm
    Take your time, and find a good deal. 247's can be had pretty cheap. This is from HK, not some ebayer.
    THX means the company paid for a fancy sticker.
    50 watts HK = 100+ watts most other manufacturers in the same price range.
    Don't get too hung on watts. You need to double them to get a 3db difference.
    Getting a separate amp used for the fronts is a good way to really start a nice system going.
    Happy hunting
    Ben
    __________________
    Ben
  • RK8
    RK8 Posts: 9
    edited March 2008
    Ben, great site. Avr 247's going for $270-300, you already saved me $100!
    I have no problem spending up to $500, the AVR 340 is going for $230, is this a lesser model? Also, the 435 is about $300, and the 445 is about $500.
    Any suggestions?
    (2)r50's
    csi3
    (4)r150's
    Thanks again.
  • RK8
    RK8 Posts: 9
    edited March 2008
    Don't quite yet know how to navigate this site, thought I had to put new thread to get response.
