RM20 Speaker Size Yamy HTR5960
Marell
Hi, not sure if this is where to post this question.
I have the following ghetto setup:
3x Polk RM201 as Centre & Fronts
4x Polk RM101 as L/R Surround & L/R Back
Polk PSW12
Yamaha HTR5960 7.1 Receiver
It's the FS RM20 Package with a added pair of RM101 for 7.1
In the Sound Menu under Speaker Settings the Yammy has a speaker size setteing:
Front speaker Small/Large
Centre speaker Small/Large
Surround speaker Small/Large
Surround Back speaker Small/Large
The Yamaha Manual states:
Select "Small" if you have small front speakers that do not reproduct low-frequency signals effectively. The low-frequency signlals of the front left and right channels are dirrected to the speakers selected in "LFE/Bass Out"
Select "Large" if you have large front speakers that reproduce low-frequency signals effectively. All the front left and right channel signals are directed to the front left and right speakers"
The above blurp is repeated for all speaker's front/centre/surround/surround back.
Am I correct in assuming that all of my speakers should be set to Small?
Thank you in advance.
Marell
Polk PSW12
Marell
Post edited by Marell on
Welcome to the forum.
Yes. Set all speakers to small.I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
Hi Obieone, thank you.
Marell
