amp
Systems
Systems Posts: 14,873
edited December 2002 in Car Audio & Electronics
I have two MM124's and i want to put an amp to them. I was thinking the Rockford Fosgate 750x (375x2 @4ohms). I dont need the subs to be really loud. Anyone have anything against it, or a better amp? Please let me know
Testing
Testing
Testing
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    the momo 12's are 500 watt rms subwoofers, and they should be fed about 450 clean watts at least to get "good" performance out of them without risking damage due to underpowering (resulting in distortion).
    if you're a rockford fan -- bd 1000.1 will work well. it'll push 1050 - 1100 at 13.8 volts. two smaller 2 channel fosgate's pushing 450 - 500 each will probably cost you a good deal more money, so the bd 1000.1 is the best rockford bang for the buck when it comes to two mm124's
    if you're looking for cheap -- a JBL BP 1200.1 is like 275 bucks shipped on ebay and it'll do 1200 x 1 -- nice little amp... and you're assured of 600 watts per sub.
    ideally for best performance, you oughta look for an amp that will push 600 - 750 per sub.
    The Artist formerly known as PoweredByDodge
