Intermitten internet connectivity test
AsSiMiLaTeD
Without getting into all the details...I'm having intermittent connective issues. I'm looking for a test that I can kick off for a couple hours to continually run and monitor internet speeds, and give me a report at the end of my connection and speed rates, say by the minute.
It's basically one of those internet speed tests you can run online, but one that I can set to run continuously.
You guys know of anything?
Post edited by AsSiMiLaTeD on
You wouldn't happen to have a sample script you could post, would you ?Sal Palooza
A ping is tiny and not a test of bandwidth, so you may have to find something else. Torrent a few 'movies', and use the 'status' at the end to check your average. You could also open the Admin log files to see if you generated any DHCP errors or timouts during that timeframe.-Ignorance is strength -
