need your thoughts please
aud10n3wb13
aud10n3wb13 Posts: 84
edited March 2008 in Vintage Speakers
I have an RTA 11T speakers. I'm currently designing my theater. I'm attaching a drawing which contains how I want to put my speakers. I'm going to make an empty space enough to accomodate the 11Ts. Am I correct that sound won't be affected since it's not ported, does not have port at the back?
Thanks!
Post edited by aud10n3wb13 on
  • zingo
    zingo Posts: 11,258
    edited March 2008
    I think it would work acoustically. Visually, it looks awesome! You would want to make sure that the front baffle of the speaker is at least flush with the wall so you don't get any diffraction. As far as the acoustics of putting them into "wall enclosures", some one will chime in. I don't think it would hurt, but I am not the expert on these things.
  • Joe08867
    Joe08867 Posts: 3,919
    edited March 2008
    It might mess with some of the bottom end of the speaker but like Zingo said if you keep them flush you shouldn't get diffraction. Boy that was a long sentence.
    The idea looks good on paper though.
  • jakelm
    jakelm Posts: 4,081
    edited March 2008
    That pic is **** with my head....:(
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • aud10n3wb13
    edited March 2008
    Thanks guys! I'm glad that it will work.
    jakelm,
    I did not get what you posted. What do you mean? Are you saying you cannot see the drawing? If so, I'm attaching it instead.
  • zingo
    zingo Posts: 11,258
    edited March 2008
    All he's saying is that the way the lines lay is a little trippy.
    heiney9 Posts: 25,421
    edited March 2008
    Yes, it will affect the sound as they are now. It's like putting a speaker inside another box. The bass will probably be more boomy and you will lose both vertical and horizontal imaging compared to having them free standing out in the open.
    Of course this is going to happen with just about any speaker you choose to place in an enclosed space. I understand the aesthetics, etc. but you will lose some of the great imaging these speakers were designed for.
    Of course I'm speaking strictly from a music 2-channel POV. If it's primarily going to be used for multi channel HT the effects of putting the speakers in an enclosed space may not even be noticeable since you'll most likely have a sub and several other speakers in the room.
    edited March 2008
    Joe08867 wrote: »
    Actually you will get diffraction because with them being flush the entire wall on both sides become the baffle and the sound (highs primarily) will tend to travel along the baffle. That's one of the reasons these and other speakers are so narrow.
    edited March 2008
    Just looked at the pic again and because they are raised off the ground you will lose a great deal of bass too. Again maybe not an issue if they are for HT only and you will be using a sub.
  • HB27
    HB27 Posts: 1,518
    edited March 2008
    This will definitely be a problem enclosing the fronts as layed out.
    I/we set up a huge HT system last year for a MAJOR company to be used as a "Lifelike" training and demo room.
    Their engineer decided to Make the room pretty by doing the same thing by enclosing the front stage area. In doing so everything muddied up and actually made the sound horrible. The company complained about the sound and just by pulling the speakers out about 2 feet out of the "enclosure" it cleaned up immediately.
    Being raised off the floor the powered fronts still lost bass
    Your speaker enclosure will cause quite a few problems.
    Their "engineer" was adamant about keeping his good looking room. We tried to address the issues with sound treatments but in the end the front stage enclosures were removed to bring the system back to life.
    Good luck.
    HB
  • aud10n3wb13
    edited March 2008
    What about this? The width is 2 ft. Depth is 28" and height of the opening is 8 ft. Then I'll just have some black speaker cloth for that whole opening. My speakers will be protruding a little like 2 inches.
    Also if you notice, I didn't remove the enclosure behind the screen. I really need an enclosure since it's for my IB subwoofer.
    Ok guys, please let me know if this will work.
