Unpacking the RTi 12's Now
Finally got some 12's for the front. The rest of my system looks like this: CSi5 for center, Monitor 10's for the surrounds, and PSW125 sub. I am powering it with an Onkyo 805 except for the 12's, they get a seperate Adcom GFA 555. Will the Audessey inform me of the crossover settings and, if not, what do you think the proper settings are for each speaker? The room is rather large 18x25, with a high ceiling. Thanks for any help.
RTi 12's main
CSi5 Center
Monitor 70's Surrounds
PSW125 Sub
Onkyo 805
Fronts Adcom GFA 555 powered
I/C's from the wall of Circuit City
Wire by BlueJeans at $.65 per foot
CSi5 Center
PSW125 Sub
Onkyo 805
Post edited by c4kaboom on
the onkyo will read the RTi12s as full range(Large)..mess around with those settings, i think my 10s are at 80hz?
try crossing them over at 60 or 80hz. congrats on the new speaks devil dog. You'll want to get amps on them to make them really shine, I started out with outlaw M2200 monoblocks. Upgrade that sub when you can and you're goldenShoot the jumper.....................BALLIN.............!!!!!
If you have an 805, you should switch your surround back to bi-amp mode and wire the woofer section of the rti12s to that. That onkyo has a good deal of power in bi-amp mode.Sharp Aquos 32d62u
Onkyo TX-NR901
Behringer EP2500 - RTi12 - CSi5 - FXi5
Sonosub 700L tuned flat @ 14hZ -
Looks like your good to go,forget bi-amping off a receiver,the adcom is more than enough.May want to upgrade that sub in the future as others have also said.Check in and tell us how that bad boy sounds.HT SYSTEM-
