Sound Displacement
Dj Dave
I dont know much about Sound Displacement
i want to make a 15" Cube Sub
4 sided
every side a 15" polk sub
im willing to put the port holes needed - and willing to put the needed space inside - my main question is - how much space is needed inside the woofers
does any body understand how much space i need ?:D
4 sided
You might want to stop at 5 sides covered in woofers.
The space you'll need is 'amount of air per woofer' x 'number of woofers'. Done. Find a specific model of woofer you want to use, or set a limit on the size of the box to narrow a woofer.
