PS3 server PISSING me OFF !!
Willow
I can't play for more than 15-20 mins without geting booted really Fn pissing me off, if it continues PS3 is going back.......:mad::mad::mad::mad::mad::mad:
Post edited by Willow on
hang in there.
I keep getting server connection timed out !!
Has it always been like this?
what nat type do you have and all that?
http://www.ps3forums.com/showthread.php?t=74303 -
Willow if you are using the ps3's wifi then your issue lies there. The built in wifi is the weakest link to an otherwise great system. Hard wire is the way to go. -
I seem to get server timeouts only when playing with you willow... otherwise it only happens very rarely.7.1 HOME THEATER:
Center: CSi3
Front: RTi10
Surround: RTi A3
Rear Surround: RTi4
Subwoofer: Mirage Omni S10
TV: Sharp Aquos 42" 1080p LCD
Receiver: Onkyo TX-SR805
Blu-Ray Player / CD Player / DVD Player / Media Server / Game Console / Best money I've ever spent: 60GB PS3 -
I can't hardwire...I don't think so. HT room isin the finished basement (stairs are open to the 2nd fl office is on 2nd fl...What to do? -
Maybe go into the internet settings on your PS3 and check what your sigal strength is for the wirless internet. If its below 50-60% then that might be your problem, and the only thing I can suggest is moving the PS3 and your wireless router closer together.
Also check your nat type like bruss suggested.7.1 HOME THEATER:
Center: CSi3
Front: RTi10
Surround: RTi A3
Rear Surround: RTi4
I'm at 60% I'm on the phone with our ISP as they cut the ethernet cable wich would allow us to use the hardwire system in our IBM homesmartbox. I'm going to get them to come fix it/replace it so I can use this feature. In the mean time I'll see about moving the PS3 around to see where I get better signal.
sorry, what is nat?
NAT is your connection type. You at least want a NAT 2. But unfortunately hardwiring the ps3 is really the only way to go.
ok I have nat2 ......
So that is good. Trust me getting to NAT2 is a major PITA. So you already being their and not knowing it is a very good thing.
So I spent 1hr on the phone with them and they say since I can't proe that their tech cut my line, it's up to me to have it fixed. Ohh they gave us a month free for the issue....great I don't care for a free month I want my cable replaced !!!!
So now I don't know what to do, does anyone have experience with this ****? -
I bought a signal booster I'll see how well that works, till I figure how to hardwire the PS
Can you get ahold of an ethernet cable crimper? It's pretty easy to make your own or fix cut cables with one. Just have to get the order of the cables correct and you're good to go.
Or call a local phone installation company to see if they could make you a cable.:eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More"
Sony cx985v (for now)
BBE 482i
B&K AVP 1030
Adcom GFA 555 mk 2
AudioQuest Crystal 2 spk wire
Nordost RCA
SDA 3.1 tl RD0 tweets
Belkin pf60
Carver TFM 55x
Signal Analog 2 RCA
AudioQuestType 4
VMPS Original Tall Boy (Mega Woofers soon) -
I'm looking into that as well, there is another option, that is to find a way to fish the ether cable from the office which is on the 2nd flr up to the attic as there is one of those pre-installed tubes for a sat. cables to run from the roof to the basement, So I could fish it down there to the HT room in the basement.
Now with the range extender, I have not yet been booted.. keeping my fingers crossed, I have 30days to return it, so I'll keep it till the very end and see what it can do for me, that is until I can find a way to hard wire the system.
Why not try out the netgear adapters that let you use your houses electrical wireing for your network. That is if the signal booster doesn't work. Good luck!
the7comeback7ki wrote: »Why not try out the netgear adapters that let you use your houses electrical wireing for your network. That is if the signal booster doesn't work. Good luck!
and what is this netgear ? -
OK, soon you won't have to be apprehensive of playing with me on line as I ordered that Netgear item, it's the best way without having to do lots of work. I can't wait !
JF, I've got maybe 100 feet of cat5 left over from wiring my apt.
I'm out of connectors, but I have the tool and the experience. Let me know if you need a bailout. Connectors will cost you $ 10 at most (should be $ 0,50 a piece in my book) plus a few beers for my labor. -
I am now hardwired, so please do not be afraid to play with me
Glad everything is up and running Willow. Have fun.Michael
NORTH of 60° -
What the hell did we do for fun as kids????????????? We had no video games, no Internet, no broadband, no cell phones, no text messaging no....
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Well right now, the ethernet cable is 50' long and running from the office on the 2nd floor down the open staircase to the HT room in the basement, there is no way this is WAF. But it's been ok'd till I get that Netgear wired system.
