Need Subwoofer Advice
Hi Everyone,
I have just joined and would like some opinions on what subwoofer to add to my system. We have had the pieces for a while, but are now going to finish the system for home theatre use. Here are the speakers I will be using:
Fronts: RT-1000P
Center: CS245
Rears: R10
The receiver will be an upgrade to a Yamaha 663. We will be using this mostly for TV use, 5.1. Any advice would be greatly appreciated. Thanks.
Fronts: RT-1000P
Center: CS245
Rears: R10
Post edited by gregbuck on
Hey Greg; welcome. A budget would help. Room size is also critical to pick a sub. SVS is a "preferred" brand, and they can work with you to recommend the right sub. The new Polk line is also very good._________________________________________________
Would like to stay under $250 or so, and would prefer to stay with Polk if possible(but would look at others and would look at used ones also). Room size is 14x14x8. Thanks.
For under 250. Good luckLiving Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
With $250 you might be lucky and find something good in the used market; your room is not big so that's a plus. But, I would strongly recommend you save a little more and get in the $400-$500 range, which will buy you a much better sub. If you buy now, chances are you'll still want to upgrade later, and might lose some money in the process._________________________________________________
Wrong forum.
OK, I could increase the budget and would look at used or refirb. Suggestions?
Wrong forum.
Why's that??? Isn't a sub a speaker. Definetely try & stretch your budget. This way you make one purchase & your satisfied. Velodyne, Polk, SVS, HSu, REL, Revel, Totem, ML, JL Audio all make great products. There's other companies but that's enough to start with."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
If you could get this it would be a very good option; this was my first "real" subwoofer and performed very well in a much bigger room. You won't have many in the used market though.
http://www.svsound.com/products-sub-box-10nsd.cfm
From Polk, I wouldn't get anything below this one:
http://www.polkaudio.com/homeaudio/products/individual/subwoofers/dswpro500/_________________________________________________
I would look for the POlK psw 450/550/650 awesome subs on the used market from around 200 bucks. The 450 was a particularily nice sub.
RT1 -
for $250 new, Bic H-100 is your best sub period....!!!!!!!!!!!!!!!!!!!
honestly, polk subs are not great...get more for your dollarVideo: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83 -
This is not a sub forum.
There is a separate sub forum. -
Yes, and a moderator can change it if they consider it so important. But this will not stop people from responding.
Any recommendation on the topic of this thread? Then why bother to post? :rolleyes:_________________________________________________
Well I say they are. And I am always right.
RT1 -
The new DSW line is miles above the performance of the Polk subwoofers of the past. There isn't anything special about the BIC H-100....period.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
How does the dsw line hold up gainst similar priced svs subs?
What's wrong with that BIC sub?
If you call HSU and speak with Pete, he will spend all the time needed to find the right sub for you. They make excellent subs and price points are spot on!:DThere are two types of people in the world, The Ones that do, and the ones that wish they had! What are you?
MARANTZ 7002
RTi8'S
CSi A6
FXi A4'S
HSU VTF 3 - MK3 (IT'S HERE)
PANASONIC 50 IN PLASMA
PANASONIC DMP-BD30 -
I would be interested to see how the HSU stf-1 stacks up against av123's x-sub.
Subwoofer guide on this site recommends the PSW505 sub. Any opinions on this choice? Thanks to everyone for all their help.
Go with the DSW500, it's better than the 505."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
The guide is a few years old. Check out the new DSW series.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
engtaz
obviously you did not read his price limit on subwoofer:(...that's $250. :rolleyes:..
NO one said anything bad about DSW line subs....besides you can't have them under $250 anyway.:)...Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
Found a deal for a PSW 303 that would fit my budget. Thought on this one in my system. Thanks to everyone for you help.
