My PSW10 hums
gocard
When I plug in the electrical outlet on my PSW10 subwoofer (with nothing else connected), I immediately notice a low hum. Even with the switch set to off. When I set it to on, the hum gets a little louder.
I only notice it when the room is silent, but it's kinda annoying.
What's the likely cause? Electrical noise over my lines? Or is it simply a bad sub?
Thanks.
Thanks.
Post edited by gocard on
Hello,
In all likelihood what you are hearing is called, "transformer lamination" noise caused by the building and collapsing magnetic field around the sub-woofer's AC transformer. This can be fairly common and doesn't indicate any problems with the unit. In fact it will become less noticeable after a few months of use. Usually it is sufficiently low in level as to not be heard unless your room is very quiet.
I hope this is helpful.
Regards, Ken
