Need some help.
the7comeback7ki
I have about $400 to spend on a receiver and subwoofer. I currently have r50's and a csi3 up front with r150's in the rear. room is only about 10x12. Any help is appreciated.
Post edited by the7comeback7ki on
Save for some good equipment, you have a good start.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
Seems I will have to extend my budget. At this point I was thinking either a harman/kardon 146 or 147, and the av123 x-sub in cherry to semi-match my polks. Any comments on either of those that anyone has from personal experiance?
go for SVS sub, and get a receiver that offers preouts on the back in case you wanna use external amps later on.Shoot the jumper.....................BALLIN.............!!!!!
Check HK Direct on ebay for a refurb if so inclined. Great deals. Definitely make sure of the preamp outs.
IMO I always recommend multi zone receivers also. I end up using the second zone sometimes, (although it may add marginally to the price) and a receiver is often a piece of equipment you use in other rooms as you upgrade your primary.
Thats good advice on the pre-outs. It sounds like you are just getting started so try looking here, and reading the reviews:
http://reviews.cnet.com/4566-6466_7-0.html?tag=ont.ha.av
This is absolutely, positively where you should buy a sub. They often have b-stock.
http://svsound.com/
If you are trying to save cash, just buy used! Everyone does it. You can do that here:
http://audiogon.com/My Main Gear
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
Panamax M5300EX
Thanks for the advice. I will definately check that out. Those svs's sure look pricey though:eek:
the7comeback7ki wrote: »Thanks for the advice. I will definately check that out. Those svs's sure look pricey though:eek:
They're worth every penny you invest into it trust me, I have two.Shoot the jumper.....................BALLIN.............!!!!!
I have two as well. I bought passive subs and drive them with my amp. This is definitely next level for you but you can get a good deal on something that is smaller, and b-stock.My Main Gear
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
Panamax M5300EX
Won't one of those things dominate my current speakers something fierce? I dunno I was thinking x-sub at 150 rms would be a good match. But I'm a rookie so go figure
If you have the settings right it should not overpower your speaks. My deal is to buy the best of whatever I am buying so there is less desire to upgrade later.My Main Gear
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
Panamax M5300EX
spend your money on a decent receiver.. and forgo the sub right now.. and run your R50's on large. they will do ok for bass. then when funds allow.. look into a nice DSW sub from Polk.
PolkFest 2012, who's going>?
Just blow off the sub entirely right now bro. Danger Boy is right get a good AVR to quarterback your system.My Main Gear
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
Panamax M5300EX
I bit on a H/K 146 for a good price. Powers my speakers plenty and I will be able to live without a sub for a bit. Enjoying some crystal clear audio.(ok I am sure I can improve much but it beats logitech computer speakers
) Time to save some cash for a sub now!
Are dsw polks good for the price point? Never heard one. -
the7comeback7ki wrote: »I bit on a H/K 146 for a good price. Powers my speakers plenty and I will be able to live without a sub for a bit. Enjoying some crystal clear audio.(ok I am sure I can improve much but it beats logitech computer speakers
Well I guess you don't have to listen to good advice.
NO PRE-OUTS!
http://www.harmankardon.com/back.aspx?prod=AVR%20146&cat=REC&sType=&Region=USA&Country=US&Language=ENG&ImgName=AVR146B.jpg
You saved the wrong dime in the wrong spot. With Pre-outs you have room to expand until you start getting silly with components. No Pre-Outs limits your whole system.
Sorry about being blunt, but you really need to spend a little more to do it right. Its kinda like buying a Chevy Chevette. Yes Chevy makes some decent cars, but there are many option, and performance lacking aspects in a 147. You can get much better for little more.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
He said it.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Ben -
Ben -
danger boy wrote: »spend your money on a decent receiver.. and forgo the sub right now.. and run your R50's on large. they will do ok for bass. then when funds allow.. look into a nice DSW sub from Polk.
And He said it.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
This is solely for a tiny-esk room. I would be concerned for my health if I ever needed external amps to power anything...I still have 30 days to return the receiver if I don't want to keep it. I am still testing the waters with it. I know I didn't follow the "get preamps" advice. But those cost about 200 bills more. For a rather simplistic surround set up it seems unnecesary?
edit: I completely appreciate the advice, but given the budget and the room situation, Pre-amp outs just don't seem to be able to fit. I am sure if I had more cash to put into the system and a better environment External amps would be awesome. -
Thats cool. If you plan on keeping it in a small room, and plan on running smaller speakers with it at moderate levels you should be fine. HK is a great begining receiver that has a very nice sound to it. A receiver from HK direct can be had for about $250 with pre outs. You just need to take your time, and not jump on the first "deal". BTW amps are not necessarily for going louder, but also add quite a bit to the SQ.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Yeah when I bump up to a bigger room I will definately invest in a better receiver than what I can afford right now anyways. Not trying to come accross as an idiot that doesn't listen to advice. Just went with what was practical for my application.
