Jolida 502B OR 801A
PRC
I am considering upgrading from my Jolida hybrid (1501RC) to a tube 502 or a 801. Any opinions on the difference in sound and power between the two.
I am a little concerned that the 502 (60 watts) will not be enough to "blast" the music. My speakers are fairly efficient and easy to drive. I really like the 1501, but I am looking for something more musical, but with good base.
Patrick
Patrick
Jolida JD1501RC -Telefunken tubes
Jolida JD9 Phono Stage
Rega P2- Dynavector 10x4 Mk.II Cartridge
Music Hall mmf cd-25
Canton Ergo 900 DC
Polk PSW404
Kimber "Timbre" IC's
Tributaries "SP4BW" - bi-wired
Canton Ergo 900 DC
Polk PSW404
my 502 is awesome and you can absolutely blast the speakers if you need to.
