home theater pics
BAD ASP
BAD ASP Posts: 361
edited March 2008 in The Clubhouse
I took a couple of pics of the home theater. Some folks here like pics so here goes.
I've got a little bit more cleanup to do with hiding wires and some trim work but so far so good. On the left is the svs pb-13 ultra, 1.2, equipment (see sig), two lsic centers, klipsch sub and the other 1.2. The two rears are lsifx not shown. The acoustical ceiling also has two inches of insulation above with an additional air gap of 8" to the ceiling joist. The room dimensions are 16'0" X 30'0" and 7'6' high. Roughly 3600 cu. ft.
Amp: sunfire cinema grand signature 5ch 425 wpc
Side surround amp: Sunfire 2 X 300
Processor: sunfire theater grand V
Fronts:: polk sda-srs 1.2
Rears: Polk LSiFX
Side surrounds: Fxi5
Center: (2)polk LSiC's
Sub: svs pb-13 rosenut
Hd-Dvd: toshiba xa-2
Blue Ray: oppo bdp83se
Projector: sony vw60
Screen: Da-Lite 106"
APC S20 Power conditioner
Post edited by BAD ASP on
  • petrym
    petrym Posts: 1,912
    edited March 2008
    Dude, that is Bad ASP! :D
  • BAD ASP
    BAD ASP Posts: 361
    edited March 2008
    Sal, not sure what you mean longwise. The wall they're on is the 16'0". I never tried them facing across the room width wise. Behind the seating there is a pool table and the rear speaks are on the wall facing each other about
    3'0" off the far end wall. Movie effects are pretty cool.
    Rears: Polk LSiFX
  • zingo
    zingo Posts: 11,258
    edited March 2008
    That is a sweet set-up! Congrats on the Polk amazingness.
  • shadowofnight
    shadowofnight Posts: 2,735
    edited March 2008
    Yeah, you should have gone bigger with the speakers :eek::) Thems too little ;)
    Nice setup
    The first rule of Fight Club is you don't talk about Fight Club
  • Sherardp
    Sherardp Posts: 8,038
    edited March 2008
    that is a sweet room bro. setup looks awesome.
  • Ron-P
    Ron-P Posts: 8,520
    edited March 2008
    Most impressive!
    Now, grab yourself some black electrical tape and cover all those distracting lights on your gear.
    If...
    Ron loves a film = don't even rent.
  • cfrizz
    cfrizz Posts: 13,415
    edited March 2008
    Wow! Very nice, congrats!
  • fumoffu
    fumoffu Posts: 80
    edited March 2008
    Awesome!
    Nice setup
    I'd say that about the sub! A sub must be bigger then the speakers!
    For a few reasons, I have been thinking about putting in acoustical tile for my ceiling. Have you had any vibration or buzzing problems?
    Home Theatre: Epson 5020ub, Elite Screen Sable Frame 100", Onkyo 818, Oppo BDP-103, Tivo Series 3, Xbox 360, Sealed Dual Sound Splinter RL-p 15" DIY sub powered by Behringer EP2500 with FBD, QSC RMX1400 powering LSi15, LSiC, LSiFX sides, and Lsi7 for the back, Technics SL-1200M3D
  • BAD ASP
    BAD ASP Posts: 361
    edited March 2008
    nmnmnmnmnm
    Rears: Polk LSiFX
  • BAD ASP
    BAD ASP Posts: 361
    edited March 2008
    Ron P... black electrical tape is way too expensive, I was planning on using duct tape.... Hey I kinda like all those pretty little lights.
    Fumofu... No buzzing yet. I don't know if the weight of the insulation above helps "load" them or if the fact that I used screws to fasten the perimeter track to the wall headers. The screws were actually a lot easier for me and it seemed to cinch down the track really well to the wall headers.
    Thanks everyone for your comments.... it is much appreciated.
    Rears: Polk LSiFX
  • Fireman32
    Fireman32 Posts: 4,845
    edited March 2008
    Looks great man.
  • BAD ASP
    BAD ASP Posts: 361
    edited March 2008
    FWIW.. when I planned this room as the kids rubber room (basement) years ago I decided to use 1/2 " marine plywood for the walls instead of drywall. I did this because of the play characteristics of boys. I also wainscoted the lower half so that it would stand up to slap shots etc. You treat the ply the same as drywall and tape the joints. The main purpose of the dropped ceiling was to have access to the ceiling space for speaker wiring and easy repair (tile replacement) when someone dented it with a cue ball, puck, cue stick, hockey stick.....you get the picture. I did place speaker drops in all the corners as well as the middle of each wall. The conduit just stubs straight up and the wire is easily fished. It may not be perfect but it is really easy to change up the room.
    Rears: Polk LSiFX
  • BIZILL
    BIZILL Posts: 5,432
    edited March 2008
    can i come watch movies with you?
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • steveinaz
    steveinaz Posts: 19,538
    edited March 2008
    Cool set-up, there's alot of Polkies with some cool theaters.
  • nikolas812
    nikolas812 Posts: 2,915
    edited March 2008
    You used 1/2" marine plywood instead of drywall?!?:eek: Talk about a price difference.
    Sweet Room by the way.
    Can I come over too?
  • obieone
    obieone Posts: 5,077
    edited March 2008
    Yeah, when's the open house!
  • BAD ASP
    BAD ASP Posts: 361
    edited March 2008
    With 5 kids our house is always open. Thanks again guys for all of your kind remarks.
    I decided on the marine plywood as it is a basement and the thought of continuous repair kinda convinced me it wasn't a bad way to go. I think I bought 25 sheets which if the difference was 15.00 a sheet the add cost was only $325.00. For that money it was well worth it. The walls show almost no wear.
    Rears: Polk LSiFX
