Replacement CC for RM7600?
rackmount17
Hi, I have the RM7600 and have been very happy with it. I am moving to a location where there will only be a shelf with 18"x5.5" of space for the center and the RM4600 CC is 22" wide - is there an adequate replacement from Polk that will complement the system? I was thinking RM202? The other Polk CCs are either too wide or too tall...Opinions welcome..thank you!
The other alternative would be to get a complimentary 5-pack and keep the PSW650 sub, but I'm sure it would be more cost effective to just replace the center!
Post edited by rackmount17 on
Hi I have an RM7600 set .. you should check ebay .. I see them there often and I have picked one up on there to use as a 6.1 for these speakers.
