speaker wire
martin margolis
hi.Speaker wire that has the name of the company on one side of the wire an
indication of positive or negative?
Post edited by martin margolis on
It doesn't matter. The wire is the same, the only important thing is that you're consistent. I always treat the "labeled" wire as Red.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
Yup, as long and the labeled side goes on the same side (red or black) on the amplifier and speakers, you are in business.
Also, this is just a testing area. You will get a better response be posting your question in a corresponding section.
