electrical question..
AdamRagland
i purchased the panamax 5300 a while ago and just moved into a new house where it is being hooked up for the first time. i have noticed over the last month in the house that the voltage meter on the panny gives me very unsteady readings. anywhere from 117-125. seems like everytime i look at it the voltage is different. should this be of concern? i thought stable power was a must. someone smarter please help me out here:)
Post edited by AdamRagland on
Of course ideally you want stable voltage but you are well within the threshold and you have nothing to worry about.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
I thought the point of the Panamax was to take those fluctuations and even them out?
Apparently I don't understand line conditioners.If you will it, dude, it is no dream. -
117 is not low at all.
If you want consistent voltage all the time you'll need a UPS."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
The fluctuations are within the acceptible range. Not that big of a deal. If it jumps over or dips below the acceptible range, then the 5300 should correct it.
I think the A/C generator models will keep you at a fairly steady 120v. Also keep in mind that the meters may be showing you the input voltage, not the output voltage. -
bobman1235 wrote: »I thought the point of the Panamax was to take those fluctuations and even them out?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
ah ok thanks for the input..
