new subs
lebo_2bnvn
lebo_2bnvn Posts: 5
edited March 2008 in Car Audio & Electronics
hey just bought a new sub box with three subs...it fits 5 but it only came with three..it fits four 10" on the side and a 15" on the top...i jus wondering what fabrication i can do to the box? any suggestions?
thanks
Post edited by lebo_2bnvn on
  • lebo_2bnvn
    lebo_2bnvn Posts: 5
    edited February 2008
  • Toxis
    Toxis Posts: 5,116
    Who designed that? Slap them in the head. Second, what kind of fabrication are you looking for?
  • black magic
    black magic Posts: 669
    I gotta be honest with you, man... that enclosure looks much too small for one 15" and four 10" subs.
  • Greg Peters
    Greg Peters Posts: 605
    lebo_2bnvn wrote: »
    thanks
    As for working with that box, you'd be better off starting from scratch. I hope you didn't pay good money for that. What type of subs (can't tell from the photo)?
  • eloplayspolo
    eloplayspolo Posts: 1,117
    that doesnt look like 4 10s from that angle, it looks like a 15, 2 10s or 12s, and 2 8s
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • ilikesound
    ilikesound Posts: 355
    what IS that?
    At Home:
    Panasonic 42'' TC-L42U12 LCD
    Pioneer VSX-80TXV
    Toshiba HD-XA2
    Sony PS3 - psn "metalguitars"
    Xbox 360 - gamertag "giggidygiggidy"
    Panamax 4300EX
    Polk RTi8's
    Polk CSi3's
    Polk FXi3's. (x2)
    Martin Logan Dynamo (x2)
    Audioquest interconnects and wires.
    Away From Home:
    JVC HDR-50
    stock system in new car for now:(
  • DemonAstroth
    DemonAstroth Posts: 131
    Elo,
    I think that your 2 8's are some sort of vents and that the other 2 10's or 12's are on the backside
    It could look sort of cool, but it's certainly not built for the sound.
    What kind of subs are those?
  • eloplayspolo
    i wonder if it makes big **** sounds ?
    2013 Toyota Prius
    Mosconi 6to8 v8
  • Jstas
    Jstas Posts: 14,999
    I'm thinkin' that that enclosure was meant for a passive radiator design with the single 15 being the active driver and 4 10's being the passive radiators. If that is the case, those ports shouldn't be there. Otherwise, unless that enclosure is compartmentalized, that's just not going to work out well at all.
    Expert Moron Extraordinaire
  • lebo_2bnvn
    lebo_2bnvn Posts: 5
    edited March 2008
    umm the top 15" is a rockwood 800w chrome sub...the two on the sides r sansui 10" d-bass
    i onli payed $100 for it so it wasnt that much of a waste...i was thinking about changing the wood to fibreglass and onli leaving the two airholes on the side...then buying four 10 inch kickers with a 15 inch competition kicker..the inside has spnge padding with plenty of room..its about 1.2 meters wide by 50 cm high
    keep posting comments..thanks =]
  • lebo_2bnvn
    lebo_2bnvn Posts: 5
    edited March 2008
    and i was just looking to make it appeal more...lik for show sortof...i was thinking silicone sheet metal down with liquid nails but tried one side and didn look good so didn complete it...i was also thinkin tidying up the wires or running the wires under the sponges for neatness and putting neons in the that pulse or something
  • lebo_2bnvn
    lebo_2bnvn Posts: 5
    edited March 2008
    all you can see is the 2 vents..the two 10" and the 15"..theres two more 10" at d bak
