Amp for LS90's
NotaSuv
NotaSuv Posts: 3,871
edited February 2008 in Vintage Speakers
well its clear to me that i need more power....hhmmm thats how my other addicton began too...but it was with trucks....looking at these 3 all within my budget used...denon poa 2800, carver tfm 35 the only of the 3 i have heard and it was pretty sweet..and the adcom 5503 3 channel so i could also hook in the center channel a 350ls..using a denon 3806..thanks
Post edited by NotaSuv on
  • Ron Temple
    Ron Temple Posts: 3,212
    I had a GFA555(I assume it will sound similar to the 5503) here for awhile and preferred the laid back TFM 35, but most Carver fans do. The difference was that probably the Adcom was more accurate, but for me the detail was too forward and in your face. The Carver layered the detail into a deeper/wider soundstage, and yes, the highs are slightly rolled off. So I gave the Adcom back. The Carver is now running my surrounds cuz my Luxman M-117 is just a bit better, to my ears, than either.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • zingo
    zingo Posts: 11,258
    I agree with the Carver. I have one of their older, PA amps that is very high quality and sounds great at home. I modded it to run quiet, and at 600wpc, it will drive anything.
  • amulford
    amulford Posts: 5,020
    I'm a third on the Carver...
