LED's on Panamax are fading fast
ilikesound
One of my bank LED's has failed, and another one is biting the dust, slowly fading out into nothingness. should i be concerned with the actual performance of the device, or should i just forget about it? I doubt it would harm anything, these things die sometimes, but if my unit were to bite the dust i would feel quite unprotected...
put my mind at ease!
At Home:
Panasonic 42'' TC-L42U12 LCD
Pioneer VSX-80TXV
Toshiba HD-XA2
Sony PS3 - psn "metalguitars"
Xbox 360 - gamertag "giggidygiggidy"
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Martin Logan Dynamo (x2)
Audioquest interconnects and wires.
Away From Home:
JVC HDR-50
stock system in new car for now:(
Pioneer VSX-80TXV
Toshiba HD-XA2
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Away From Home:
JVC HDR-50
Post edited by ilikesound on
I wouldn't worry about it too much. However, Panamax customer service is pretty darn good. Give them a call. They might fix the LEDs and run it through the gauntlet and refresh it for little to nothing.
It should not effect the performance of the unit, but it is weird that they are fading rather then just quitting. If they just quit one day, it would probably be a fault on the circuit board, but fading could be a problem with the power supply to the unit, because LED's usually last over 100k hours. I would contact Panamax.
Venom -
One of mine is fading also. It has gone completely out a couple of times but comes back. It is been in a slightly faded state now for @ 9 months.I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Heck, I cover all mine up with black electrical tape. I hate lights on gear, nothing but a distraction.If...
Ron loves a film = don't even rent. -
If you are electronically inclined, make sure that your 12v that powers the board or circuit is at or near 12v's and / or look for a bad solder connection in between the 12v supply and the LED circuit.
If you are not electronically inclined, call for service and see what they recommend for you to do. If the LED's do not coincide with hampered performance and the dimming doesn't bother you, don't worry about it. Unless it's a LED that is supposed to inform you that the unit has an internal problem, in that case shut the unit down and refer to the owner's manual before calling for service / warrantee work.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
i tried to contact them, via email, but never got a response back..i'll try again, but if that fails, there isn't a number that i'm aware of that i could call..
thanks for the input guysAt Home:
Pioneer VSX-80TXV
Toshiba HD-XA2
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Away From Home:
JVC HDR-50
