Rti12 question
hawgfan88
hawgfan88 Posts: 12
I have a pioneer vsxd811s and an onkyom-282 amp. My question is can I bi-amp my Rti12's by using the receivers front speaker posts for the high's and using the onkyo m-282 for the lows?
Rti12's
Csi3
DSW Pro 600
Onkyo M-282
Pioneer VSX D811S
Belkin Pure A/V PF60
PS3
Wii
Philips 47" 1080p
Post edited by hawgfan88 on
  • obieone
    obieone Posts: 5,077
    edited February 2008
    I TOO would like to know how to bi-amp that particular pair since I'm looking at a pr.?
    I'm thinking of getting an Outlaw 7075 for the HT speakers, then a pr. of M200's for the 12's, then using a 'Y' splitter off the rcvr. to feed both amps at the same time?
    I saw a review online, and author said you should biamp using 100-125wpc for the HF, 200-250 for LF. I just don't KNOW how to do that another way, other than how I described it
  • Sherardp
    Sherardp Posts: 8,038
    No Y splitter needed Obione, you simply remove brass jumpers from speaker terminals, run a single RCA cable(Interconnect) from the receiver to the power amp. Run a set of speaker cables from the AVR to the top set of speaker posts(highs). Then use speaker wire and run a pair of cables from your power amp to bottom set of speaker posts(bass). Simple as that............I had my 12s biamped at one point using my AVR and an outlaw and it did sound great. Since then I am now running them off a D-Sonic Magnum 1000S and they sound even better. Give it a shot, see how you like it.
  • wizzy
    wizzy Posts: 867
    Hmm, I always heard the m-282 was kind of anemic.
    Good luck getting the preamp -> amp gains to match up at both low and high volumes.
  • obieone
    Thanks SherardP. I haven't bought the speakers yet, I'm probably gonna pull the trigger on a pr. of M2200 monoblocks to see if they help my Monitor 60's first. Tweeter's got a pr. of floor model 12's on sale for $736., that's why I'm looking at them!
