H/K 347 and optical input
Mauskar
Mauskar Posts: 104
Hey guys,
I am having difficulties with setting the digital optical output from my TV to my H/K 347. My current setup is running a Comcast cablebox to my Sony rear projection via HDMI, and them running an optical from the TV to Optical 1 port. The audio polling feature jumps to analog automatically, but no signal is being picked up using the optical. All cables are brand new- straight from monoprice. Any ideas?
thanks
Post edited by Mauskar on
  • johnny42
    johnny42 Posts: 32
    edited February 2008
    I use the optical cable from the cable box TO the HK.
  • Mauskar
    Mauskar Posts: 104
    is there no way to just run one digital optical from the tv to the receiver? I am passing all my inputs via hdmi to to tv for video processing and want to pass back the audio to the receiver...
  • phuz
    phuz Posts: 2,372
    I'm pretty sure that HDMI connection isn't passing any audio to your TV.
    You'll need to run the optical cable from your cable box to your receiver.
    *If* your cable box and receiver handle the newer HDMI formats that pass audio (I don't think they do though), run the HDMI to your receiver first, then to your TV.
  • jakelm
    jakelm Posts: 4,081
    The HDMI is sending digital to tv. Then the digital is converted to analog. It is not looped through tv to digital out.
    As far as I know. You can loop it with analog out from Tv, but not digital out.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • Mauskar
    Mauskar Posts: 104
    jakelm wrote: »
    So the TV will only output an analog signal from conversion- am i understanding that correctly?
    If so then if i run my DVD hdmi to my TV and then run an optical from my tv to receiver should NOT work since the signal down converts to analog?
    If that is the case, then what is the purpose of having a digital optical out on the TV. Doesnt make sense...
