Computer external sound card
NeilGabriel
Does anyone use this add on? If so, what is your opinion. Thanks.
Creative Labs USB SoundBlaster Live! 24-Bit External Sound Card
Post edited by NeilGabriel on
I tried it, and didn't like it very much. It also tends to eat up your CPU a bit more, if that's an issue for you.
I went from onboard to external and never noticed a difference. Maybe it would only apply to slower PC's?Polkmaniac wrote: »I tried it, and didn't like it very much. It also tends to eat up your CPU a bit more, if that's an issue for you.
Is there a reason why you want a external card? Do you own a laptop or are afraid of cracking your case open?
I would recommend this card: http://us.creative.com/products/product.asp?category=209&subcategory=669&product=14066
This has it's own processor, so it doesn't leach off the rest of your PC like a external card would. It also has AISO drivers which bypass Window's sound processing. Be sure to install it with the minimum amount of drivers needed, or it will put a ton of garbage on your computer."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
does this swap out with existing soundcard then? -
Yes.NeilGabriel wrote: »does this swap out with existing soundcard then?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
