Speaker stand for Fxi A4 or Rti4
shimey013
shimey013 Posts: 79
im looking for speaker stands for FXi A4 or Rti4
Reason i ask about both is because Im going to get the Fxi A4, and then get the Rti 4.....
any help would be appreciated
Post edited by shimey013 on
  • wizzy
    wizzy Posts: 867
    edited February 2008
    If you can afford it, I would highly recommend hiring a couple playboy centerfolds to stand in the room holding your speakers while nude. You need to get the stronger ones for this.
    Otherwise, try racksandstands.com as a start just to poke around and see what's out there while waiting for more people to reply.
