EL34 Tubes
nikolas812
nikolas812 Posts: 2,915
edited February 2008 in Electronics
One of my EL34 power tubes is a lot brighter than the the other three. Is this ok??
Edit: Never mind......I think from the looks of the tube it is made just a little bit different than the other ones.
I get paranoid sometimes when everything is not perfect.:o I think I have a minor case of OCD.
Post edited by nikolas812 on
    F1nut Posts: 52,292
    What do you mean it looks different? Are all 4 made by the same company? Have you set the bias?
  • nikolas812
    Yes the bias has been set and rechecked many times. The tubes are all the same. I bought two matched pairs from the tubestore.com
    Its hard to explain what the difference is but basically it looks like some sort of sheild is just a hair shorter than the others revealing a different brighter part of the tube.
    F1nut Posts: 52,292
    Ok, I guess you're golden.
  • beardog03
    beardog03 Posts: 5,550
    I know whayt ya mean..
    That`s what I meant when I said tha your tubes seemed brighter than mine...
    should be fine as long as they bias correctly
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
