DIY subwoofer kappa perf 12, can I use real wood ?
polkseller
I'm thinking of building m own subwoofer with a Infinity kappa perfect 12 inch sub and a home made enclosure.
I see that there is good documentation on this sub and it also has a special magnet port to tune some frequency response in box. A usefull feature.
Is it a good idea to use this car subwoofer to make my home theather/music sub ?
Can I use real 1 inch thick solid maple or birch wood to make the box or its better to use the MDF boards and wood laminate or carpet ?
I plan to use an internal BASH amplifier.
I dont know wich sound material / special fiberglass wool to put in the box..
price:
90$ 12 inch subwoofer ( huge deal)
145$-200 plate BASH amp ( 200 or 300 RMS)
50-100$ wood and material.
price:
Post edited by polkseller on
You'll get more responses from people here who are more "subwoofer guru" than I am, but I'll try and respond to some of your questions:
In general, no it's not a real good idea, but it can work. It really all depends upon the specs of the woofer. As long as you can acheive the response you're after, it can work. In general, woofers designed for auto sound have slightly different parameters that often make them less than ideal for music or home theater installations. Better woofers designed for music or HT use may have lower distortion motors (shorting rings, etc.) but lower sensitivity, for example.Is it a good idea to use this car subwoofer to make my home theather/music sub ?
I wouldn't recommend building the box from maple or birch. Although I hate MDF (nasty stuff, really), its properties are just about ideal for speaker and subwoofer boxes. It's heavy, dense, and essentially non-resonant. Also-- and this is important-- it's more dimensionally stable than real wood, and it will be much easier to build an air-tight enclosure with MDF. Less expensive, too. You can finish it however you choose.Can I use real 1 inch thick solid maple or birch wood to make the box or its better to use the MDF boards and wood laminate or carpet ?
The BASH amps are fine.
The stuffing amount/material will be highly dependent upon the actual enclosure that you end up building. A sealed box generally can be stuffed, while a ported enclosure might not need as much. -
You could try a big old vented box(3 cubic feet) tuned to 22 Hz.
Box? I picked this one up from partsexpress. Well built and finished.
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=302-820Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
Forget my plans... I will buy new polk dsw 500 and be real happy
well the specs look good on that speaker!
How does it sound?
What is good about DIY is you can build the sub to the size that fits best in your application.
