Polk Speakers and Impedance Switch
I have the following equipment:
Mains: RTi70's (bi-wired)
Center: CSi30
Surround: FXi30's
Receiver: Yamaha RX-V630
The receiver has an impedance switch that gives me a choice of 2 settings:
Setting 1
Main Speakers - If one pair of mains, impedance of each speaker must be 4 ohms or higher. If two pairs of mains, impedance of each speaker must be 8 ohms or higher.
Center - Impedance must be 6 ohms or higher.
Surrounds - Impedance must be 6 ohms or higher.
Setting 2
Main Speakers - If one pair of mains, impedance of each speaker must be 8 ohms or higher. If two pairs of mains, impedance of
each speaker must be 16 ohms or higher.
Center - Impedance must be 8 ohms or higher
Surrounds - Impedance must be 8 ohms or higher.
In the hard copy manual that came with my RTi70's the specs state that the impedance is a "nominal 4 ohms" BUT the online manual found on the polk website says that the RTi70's are "compatible with 8 ohm outputs". So I have the following questions:
1. Why the difference between the hard copy and online documentation? Was it a documentation mistake or are the speakers I actually purchased 4 ohm speakers? Were they originally manufactured as 4ohms and then newer versions manufactured as 8 ohms?
2. Does bi-wiring my RTi70's effect the impedance at all? Which impedance setting should I use on my receiver if I have the RTi70's bi-wired?
Would really appreciate your help. I'm a little nervous about powering this system up with the discrepancies in the documentation.
Thanks much!
Center: CSi30
Surround: FXi30's
Setting 1
Setting 2
Thanks much!
Post edited by faharsla on
All polks except lsi are 8 ohms, i dont see bi-wiring your speaks will make them 4 ohms, in other words, leave it set at 8 ohms man and listen away and enjoy yourselfDamn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC -
ohh yeah, about the documintation, i think alot of the manuals were miss-prints, the website is correct, all the rt lines are 8 ohmsDamn you all, damn you all to hell.......
I promised myself
Thanks for the replies! The doc that came with the speakers threw me a little. Thanks again.... -
no prob, netimeDamn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC
