Did tons of searching!!!
cantzme78
cantzme78 Posts: 58
edited February 2008 in Speakers
What I have found I think is great and am wondering what others think as well... I have already bought the RTi8's from Fry's and I have the DSW Pro 500. But then really got hot and heavy with the searching today and found the following items:
CSi5 Brand new in Cherry for $268
FXi3's Brand new in Black for $98 each
PSW 505 Brand new for $268 to replace the DSW Pro 500 that I paid $500 for!
Well what does everyone think if I run this set-up with my RTi8's and an Onkyo 805?
There are two types of people in the world, The Ones that do, and the ones that wish they had! What are you?
MARANTZ 7002
RTi8'S
CSi A6
FXi A4'S
HSU VTF 3 - MK3 (IT'S HERE)
PANASONIC 50 IN PLASMA
PANASONIC DMP-BD30
Post edited by cantzme78 on
  • danger boy
    danger boy Posts: 15,722
    ummm, i'd keeep that DSW Pro 500 subwoofer.. those new Polk subs are hot looking with some really great features built into them.. i want one.. but it would be tough to give up my SVS hybrid one. ;)
    PolkFest 2012, who's going>?
  • cantzme78
    cantzme78 Posts: 58
    The DSW Pro 500 is rated at 200 watts RMS where the PSW 505 is rated at 300, also the 500 is a 10 inch sub vs. the 505's 12 inch. So in the end is all the extra stuff the new 500 gives you worth that much more or is the 12 inch with 300 watts better then the 10 inch with 200 watts? Especially with the set-up I am considering!
    MARANTZ 7002
    RTi8'S
    CSi A6
    FXi A4'S
    PANASONIC DMP-BD30
  • bopicasso
    bopicasso Posts: 878
    Where did you find a csi5 at?
    Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
  • cantzme78
    cantzme78 Posts: 58
    bopicasso wrote: »
    I was able to find it at a store called xtreme audio it is a locally owned and operated store.
    MARANTZ 7002
    RTi8'S
    CSi A6
    FXi A4'S
    PANASONIC DMP-BD30
  • GreggS
    GreggS Posts: 12
    cantzme78 wrote: »
    The range of the DSW Pro 500 and PSW 505 are almost identical, so unless you currently have the volume on your subwoofer jacked up I don't think you'll get anything more out of the PSW 505 (as mentioned before the DSW Pro 500 has some extra features the PSW 505 doesn't since it's a newer line). I believe they are phasing out the PSW line and putting the DSW line in it's place, which is why you can get good deals on the PSW line if you can find them. Is the extra money for the DSW Pro 500 over the 505 worth it? Probably not. But if you already have the DSW Pro 500 why bother. I just got a DSW Pro 500 recently and don't even have the volume up half way. If you want to upgrade, go for the DSW Pro 600.
    DSW Pro 500
    Overall Frequency Response 23Hz - 160Hz
    Lower -3dB Limit 30Hz
    Upper -3dB Limit 125Hz
    PSW 505
    Lower -3dB Limit 28Hz
