WTB: Inexpensive Integrated
AsSiMiLaTeD
I'm on the lookout for an inexpensive integrated to drive a pair if very efficient speakers.
Things I must have:
1 - The speakers are a bit on the bright side, so something with a warmer sound is what I'm looking for.
2 - Needs to be somewhat clean. Also, no offense against the gear from the 70s or 80s, but I'd like something that is somewhat current and living room presentable - the cimpler and cleaner the look the better.
3 - Want to spend as little as possible, I'd say $300 would be my max at the moment.
Here's what I can give on:
1 - It doesn't really need to be a true integrated with source switching, an amp with a volume know (like that Sonic T amp) would work fine.
2 - I don't need much power, these speakers are highly efficient so just a few watts should do the trick
3 - I don't need a remote
4 - I prefer tubes, but ss will work.
Guys I know $300 isn't alot to play with, that's why I'm willing to compromise on some things. I know this is doable though. There are several options like the Cambridge 340C and Jolida 1301A that are just outside of my price range new, so I figured if someone here has one laying around I'd like to grab one on the used market, would like to try my luck here before hitting eBay or Audiogon.
Things I must have:
Post edited by AsSiMiLaTeD on
Its not from a polkie but you might want to watch this.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=170194659682&ssPageName=STRK:MEWA:IT&ih=007 -
http://www.audioadvisor.com/searchprods.asp
This one might work as well.
Or shoot me a PM. I might be able to help as well.Tschüss
Zach -
Heres another one. You might try and and get him down. I think $350.00 shipped would be a steal if he would do it. I don't know if you watch this stuff like I do or not so I am just throwing it out there. I don't think you could ask for much more at that price. It also wouldn't be a hybrid. Just a thought. I have heard great things about the EL84 tube.
Edit: It probably won't last long. I watch these things on the Gon daily and they go quick at that price. I would give it another day or two at the most before its sold.
http://cls.audiogon.com/cgi-bin/cls.pl?intatube&1208471516
