Rti10s Bi wiring?
Does anyone know how the Rti10s sound better with or with being biwired?
I have 120 watts going to each one so would it even be worth it to do it?
Thanks -Drake
Charleston, SC REP
Post edited by IPlay4CrackInSC on
  • J_Kennedy
    J_Kennedy Posts: 138
    edited February 2008
    Thanks -Drake
    Charleston, SC REP
    Read your post after you put the pipe down and you land again. :D
    - Onkyo TX-SR805
    - Polk RTi8's Main L/R's
    - Polk CSi A6 Center
    - Polk FXi3 Surrounds/Rear Surrounds
    - HSU VFT-2 MK3
  • danger boy
    danger boy Posts: 15,722
    bi wiring is inexpensive enough.. so give er a try... maybe it will be worth it to you.. if not.. you're not out much but a couple feet of extra speaker wire.
    PolkFest 2012, who's going>?
    treitz3 Posts: 20,239
    Not at all IMO. Waste of time and $$$.
    BTW, welcome to CP and I'm curious. Where in the heck did you come up with a user name like that?
  • obieone
    obieone Posts: 5,077
    Maybe he's a jazz musician?
  • ilikesound
    ilikesound Posts: 355
    assuming you understand the difference between bi-WIRED and bi-AMPED, here's my take on it, as well as a few well-informed articles floating around on the web.
    bi-wiring does NOT improve many, if any properties of a given speaker.
    bi-amping on the other hand is quite the subjective matter. different people say different things, but i can tell you that when i decided to hook my rti-8's up via bi-amping, that it made a noticeable difference in the soundstage and imaging than just "hookin' dem up." so i would try it, and see, every system is different, as is every environment. good luck, i hope it makes a difference!:o
    At Home:
    Panasonic 42'' TC-L42U12 LCD
    Pioneer VSX-80TXV
    Toshiba HD-XA2
    Sony PS3 - psn "metalguitars"
    Xbox 360 - gamertag "giggidygiggidy"
    Panamax 4300EX
    Polk RTi8's
    Polk CSi3's
    Polk FXi3's. (x2)
    Martin Logan Dynamo (x2)
    Audioquest interconnects and wires.
    Away From Home:
    JVC HDR-50
    stock system in new car for now:(
  • ben62670
    ben62670 Posts: 15,969
    I am assuming you are running a receiver at 120wpc. You would be better off getting decent wires than Bi-wiring.
    Ben
  • ryanjoachim
    ryanjoachim Posts: 2,046
    I was able to bi-amp my RTi10's by using the UNused Surround L/R inputs on my receiver, and...WOW. They sound a LOT better! Your receiver has to have the option for that in order for it to work though.
    MrNightly wrote: »
    "Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
    mystik610 wrote: »
    Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
    My System:
    TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
    HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
  • J_Kennedy
    I'm bi-amping my RTi8's since I'm not using the rear surrounds just yet. That's also what the Onkyo 805 is set up to use if you are going to bi-amp and do 5.1 or less.
    I hope they'll sound even better. :D
    - Onkyo TX-SR805
    - HSU VFT-2 MK3
  • SuperG
    SuperG Posts: 34
    Dont want to hijack your thread but can someone explain what you guys mean by bi-amping.
    My understanding was that bi-amping means hookin up one speaker to two amps but it seems that some of you hook the same speaker with two different channels of the same receiver :confused:
    Is there some improvement in sound by hookin up my RTi8's through two different channels of my receiver instead of bi-wiring?
  • ryanjoachim
    Bi-Amping can mean having one input on the speaker going into your receiver, and one into your amp.
    Or if your receiver is able, you can plug one cable into the top plugs on the speaker, and one cable into the bottom plugs. Then wire one into (Front L/R for example) and the other on into an UNUSED spot (in my case Surround L/R).
    It's not as good as using a separate amp, but it does help.
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
  • SuperG
    SuperG Posts: 34
    My receiver has 7.1 capabilities and also has another channel (channel B) so instead of biwiring my rti8 i can hook up the top plugs through channel A and the bottom plugs through channel B or my unused surround back and remove the jumper on the speaker?
  • ryanjoachim
    yes (the rest of this sentence is thanks to polk's 4-word minimum per post)
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
  • SuperG
    SuperG Posts: 34
    I will give it a try, thanks.
  • Parachoute
    Parachoute Posts: 88
    SuperG wrote: »
    Can you do that? I think you must have the receiver to do that (like onkyo 805) and tell your receiver that you are driving LF of the speakers with main output and HF with L/R back surround. I don't think you should do that with A/B main channel output. Am I right???
  • ryanjoachim
    If it's the A/B on the receiver, then probably not. I believe it has to actually be a different channel altogether.
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
  • SuperG
    SuperG Posts: 34
    You kinda caught my attention and now worried because I've been running my speakers this way now for almost a week. Will this damage my speakers?
    I Know most believe that passive bi-amping results in no gain but I noticed a small but real gain hookin up my speakers this way. If your running a powerfull receiver it might not be worth it but it seems that I gained a few extra needed db as my receiver only puts out 75 watts/channel.
  • Parachoute
    ...will this damage his speakers?
