Onkyo 605(B) and my setup
ryanjoachim
Here's my setup, first of all...
Fronts: RTi10's
Center: CSi3
Surrounds: FXi4's
Sub: DSW Pro 600
Now, I have heard that it is best to set my fronts to "Large" and my surrounds to "Small"...
My receiver has either "Full Band" or 20-120mhz for the speaker "size"... Which should I set my speakers for?
Fronts: RTi10's
Center: CSi3
Surrounds: FXi4's
Sub: DSW Pro 600
"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
My System:Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
Post edited by ryanjoachim on
full band on the onkyo cause the rti10 has woofers in them if you want to use themHome Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
2 Channel rig Sunfire grand cinema 5ch,sunfire TGA III,Rotel 1072,polk RTI12,Monster hts 5100 -
Hi ryanjoachim,
Onkyo 605 comes with Audessy auto setup. Just plug in the mic and follow the instructions. It will set every thing up automatically.
You can the tweak those settings manually if you like.-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
To push RTi10s, you probably should have stepped up to a 705 or 805... but since you have the 605, set the mains to full range and all others to 80Hz.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
Hi ryanjoachim,
Audyssey, as implemented by Onkyo, detects any speaker that goes below 80Hz as "full range". Those speakers will likely all detect that way, though they shouldn't be run that way. Run Audyssey, let it EQ the speakers (the Audyssey 2EQ on the 605 doesn't EQ the sub - another reason you should have gotten the 705/805), then change the crossovers manually.Equipment list:
Emotiva XPA-3 amp
Well, in the Auyssey setup it DOES "ping" the sub during the speaker setup, and last time I did it it set my sub to -12db
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server. -
ryanjoachim wrote: »Well, in the Auyssey setup it DOES "ping" the sub during the speaker setup, and last time I did it it set my sub to -12db
It's setting up the distance and the level adjustment. It's good to have the sub adjustment close to 0dB. If you lower the volume knob on the back of the sub and rerun audessy it should raise the adjustment.Home Theatre: Epson 5020ub, Elite Screen Sable Frame 100", Onkyo 818, Oppo BDP-103, Tivo Series 3, Xbox 360, Sealed Dual Sound Splinter RL-p 15" DIY sub powered by Behringer EP2500 with FBD, QSC RMX1400 powering LSi15, LSiC, LSiFX sides, and Lsi7 for the back, Technics SL-1200M3D -
kuntasensei wrote: »To push RTi10s, you probably should have stepped up to a 705 or 805... but since you have the 605, set the mains to full range and all others to 80Hz.
What about the Rti8's? I'm considering the 605 & 705, right now they have the 605 for $305 refurb. I've heard the 705 has been as low as $434 refurb in the past though. I might just wait and see if one becomes available.TV Samsung 61" 1080P DLP LED
TV Samsung 50" 1080P DLP
HD-DVR
Receiver Yamaha RX-V663
Fronts 2 Rti 8's
Surrounds 2 Rti 4's
Center Csi 3
Sub Bic H100
PS3 40GB -
I have heard so many different opinions on what to set the knob at. Is the receiver taking control of that option since I have the digital coax connected? Or is there a rule for where it would normally be set at? (mhz)"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
The RTi8's aren't as power hungry as the 10's. You'd probably get away with either and it'd sound great. But I would get the 705 so you can have pre-outs in case you decide to go the pre-pro route in the future.
I run my RTi8's from the 805 and it sounds phenomenal. I absolutely love it.Polk Audio RTi8 Fronts
Polk Audio CSi A6 Center
Polk Audio RTi A3 Surrounds
Polk Audio PSW505 Subwoofer
Onkyo TX-SR805
Sony Bravia V5100 46"
Sony Playstation 3 160GB
Sony Playstation 3 120GB Slim -
Thanks, forgive me for asking but what is pre-pro?TV Samsung 61" 1080P DLP LED
HD-DVR
Fronts 2 Rti 8's
Surrounds 2 Rti 4's
Center Csi 3
Sub Bic H100
PS3 40GB -
get the 705. The pre outs allow you to plug an rca plug for each channel into a hipower amp if you decided to external amp later on...which I just did...Rti10 front, csi5, Rti6 surrounds, PSW505, B&K200.7s2, Onkyo705.
705 is high on the list and most likely. If I can find a refurb this week I'll pick it up.TV Samsung 61" 1080P DLP LED
HD-DVR
Fronts 2 Rti 8's
Surrounds 2 Rti 4's
Center Csi 3
Sub Bic H100
PS3 40GB -
I recommend the 705 not only for the pre-outs as mentioned, but because it has Audyssey MultEQ XT, whereas the 605 has Audyssey 2EQ. MultEQ XT does hundreds of points of equalization for each speaker to correct for your room acoustics, while 2EQ does a more basic equalization with no correction on the subwoofer.
I'm running the 705 with RTi70 mains, CSi40 center and RTi28 surrounds with a SVS 20-39CS+ sub. MultEQ XT made those speakers sound SO much nicer than they did before. Plus, the 705 can do 5.1 to 7.1 conversion of hi-res audio like Dolby TrueHD, whereas the 605 doesn't have the DSP power to do it. You'll be infinitely happier with the 705.Equipment list:
Emotiva XPA-3 amp
705 it is, I like the THX certification and apparently it doesn't overheat as much or at all like the 605. What's my optimal audio/video connection 1.3a HDMI cables? I'm planning to hook my cable into the receiver and my DVD player and then run everything to the TV. Will I still be able to hear sound on the TV without turning on the receiver or will I have to run separate connections to the TV from the cable box? Right now my cable box had DVI so I'm going to try and get a newer one with HDMI so I can just get a standard cable which I'll be able to use later, doesn't seem like anyone uses DVI much anymore. ThanksTV Samsung 61" 1080P DLP LED
HD-DVR
Fronts 2 Rti 8's
Surrounds 2 Rti 4's
Center Csi 3
Sub Bic H100
PS3 40GB -
If you use HDMI (or optical for sound) from the cable box to the receiver, then to the TV with HDMI, then yes you will be able to hear sound from the TV.
You can turn that option off in the receiver if you want. It's under HDMI Audio Out."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
The only reason I got my 605B is because:
1: It was on sale for $350
2: It decoded DolbyTrueHD and DTS-HD
3: I was on a budget...and I blew most of it on the speakers themselves
ryanjoachim wrote: »If you use HDMI (or optical for sound) from the cable box to the receiver, then to the TV with HDMI, then yes you will be able to hear sound from the TV.
Even with the receiver turned off? I'm thinking more about my wife or me for that matter watching TV without the speakers (as opposed to silencing the TV when the speakers are on).
Also, the 605 is a sweet receiver and good value for $350!! I upped my budget on the speakers too unfortunately but it will be worth. That's the best place to spend it if you have to choose since you've got the decoding anyway.
I'd imagine most people won't have the overheating, and some have added external fans.TV Samsung 61" 1080P DLP LED
HD-DVR
Fronts 2 Rti 8's
Surrounds 2 Rti 4's
Center Csi 3
Sub Bic H100
PS3 40GB -
The 705 has two thermally-triggered fans underneath. I've never heard mine come on, so mine is either running really cool even under load or the fans are REALLY quiet.Equipment list:
Emotiva XPA-3 amp
ryanjoachim wrote: »The only reason I got my 605B is because:
Where did you find the 605 for $350? I'm looking at it as well. Thanks. -
I got mine on sale from TigerDirect.com
It's discontinued now though...
And lock?
As long as you leave the "HDMI Audio Out" option in the receiver ON, you will be able to turn off the receiver and just turn up the TV volume (not 100% sure about that, but it should work)"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
Thanks, I haven't bought it yet and wondering about this stuff ahead of time but I also just downloaded the manual and will do some reading up prior to arrival.TV Samsung 61" 1080P DLP LED
HD-DVR
Fronts 2 Rti 8's
Surrounds 2 Rti 4's
Center Csi 3
Sub Bic H100
PS3 40GB -
ryanjoachim wrote: »I got mine on sale from TigerDirect.com
And lock?
You're saying to have the TV on, receiver off, and the video and audio passed through the reciever via HDMI?
I don't think that will happen. HDMI isn't a passive pass thru.- Onkyo TX-SR805
- Polk RTi8's Main L/R's
- Polk CSi A6 Center
- Polk FXi3 Surrounds/Rear Surrounds
- HSU VFT-2 MK3 -
So you're probably better leaving the cable box to the TV and running a separate optical audio for when you want to hear your TV through the stereo?TV Samsung 61" 1080P DLP LED
HD-DVR
Fronts 2 Rti 8's
Surrounds 2 Rti 4's
Center Csi 3
Sub Bic H100
PS3 40GB
