Thanksgiving and now I'm annoyed!
madmax
madmax Posts: 12,434
OK, so my friend wanted an SDA cable, a real polk one, so I gave him one. My Thanksgiving is now complete, Right? Well, now I'm annoyed. I end up hooking up my 2.3 TL's because I no longer have an SDA cable for my SRS-SDA's and I need some SDA sound. I've been collecting equipment for some time now trying to get the highs a little subdued because they are a little too bright. Well, the 2.3TL's now appear too dull. DUH! You would think the different SDA's would be pretty close to each other? Not at all!!!
madmax
Vinyl, the final frontier...
    F1nut Posts: 52,005
    edited November 2002
    I always found the SL2000's to be bright, but I am very happy with my 2.3TL's and the SL3000's. Maybe you need to let your ears adjust.
    BTW, you did a good thing. Happy Thanksgiving!
  • audionutt
    audionutt Posts: 97
    are they the pin blade or blade blade?
    joe
  • madmax
    The SDA SRS are blade/blade. I know the wire quality for this connection probably doesn't matter much but I figure I will make a cable out of some quality wire. As for the connectors I've heard Radio Shack may have them but I couldn't find any the other day. Maybe I can order them or go ahead and upgrade the connectors at the same time.
    madmax
