Projectors 101
CAvolleyballguy
CAvolleyballguy Posts: 156
edited February 2008 in Electronics
I think I want a projector...
you all educated me on upgrading my HT...
I want HD. I like watching movies and sports a lot. I watch a few shows on TV but I definitely spend a lot of time in front of the tube, so the unit would have to take some hours and not over heat.
I am thinking of replacing my LCD so if I am going to drop a couple K why not drop a couple more and go big. Room is dark.
Thoughts?
Rti10 front, csi5, Rti6 surrounds, PSW505, B&K200.7s2, Onkyo705.
Post edited by CAvolleyballguy on
  • Frank Z
    Frank Z Posts: 5,860
    Budget?
  • hockeyboy
    hockeyboy Posts: 1,428
    I love my Carada screen that was much cheaper than many competitors. I am also happy with my Mitsu HC5000. It is 1080P. The HC6000 just came out and it is even better since it fixed the auto iris issue. Be prepared to part with a bit more coin however. You need a screen and PJ's just cost a bit more but are totally worth it.
    You will have longer cable runs (for ceiling mount), will need a mount & screen, and should consider replacement bulb cost (although that is typically a cost that is overblown since you rarely have to replace a bulb). All in all, I would do it again in a minute. I bet I saved $700 in movie tickets last year alone.
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
  • Sherardp
    Sherardp Posts: 8,038
    Theres so many options out there its tough to choose. I guess it really depends on your budget as mentioned. The ones that are talked about allot these days are the JVC HD1, Sony VW60, Panny 2000U, Epson 1080UB. These mentioned will run you in the 2000-4500 price range with the JVC being the top performer. As mentioned go for the Carada, best bang for screens out there.
  • adam2434
    adam2434 Posts: 995
    I suggest reading up on projectors and reviews at http://www.projectorcentral.com/
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • CAvolleyballguy
    2 to 4k would be cool if I decided to go with it. thanks for the suggestions, I will check those out. also.. how dark does the room need to be during the day to get good visibility play back.
    I have two sliding glass doors in room but they open to a center courtyard so I never have light directly through window. Could hang drapes too, but the room is pretty dark as is.
  • kuntasensei
    kuntasensei Posts: 3,263
    Sanyo currently has a rebate deal for their PLV-Z2000 1080p LCD projector until the end of March. You get a $300 rebate by mail within 4-6 weeks, then an additional $300 by mail later. I snagged mine from B&H Photo for $2,249 shipped (and I hear you can find them cheaper elsewhere)... so you do the math. That leaves you more money for a good screen.
    Hit some sites like Projectorcentral.com to check reviews of the recent 1080p projectors (and projection calculators to see what your options are as far as distance and screen size in your particular room). I can tell you that I went from a 720p projector with 2,000:1 contrast ratio to the Z2000's 1080p and 15,000:1 contrast, and man... I couldn't be happier. I have mine mounted on a $20 shelf on the back wall, not too far from my head, and I can barely hear it. The Z2000 reportedly has the quietest fan of any projector (19dB in eco mode) and I've run it for 9 hours at a time with no issues whatsoever. Plus, it's bright enough in my room that it's still very watchable even with a few lights on. I'm working on tweaking it with a CC30R filter to eke out a little more contrast from it, but I already have some settings over at AVS that line up the grayscale pretty well. HIGHLY RECOMMENDED.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • Serendipity
    Serendipity Posts: 6,975
    Sal,
    How did you get the power cable to the projector?
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Serendipity
    Interesting, my electrician friend said that in NYC (5 boroughs) it is against code to do that, but I would assume that only applies to NYC and not NJ.
    He told me that in NYC you must run BX cable to the projector mount since you can't use romex in the wall.
  • Serendipity
    Haha, I wasn't really talking about your install, I was more concerned about doing it right for my setup in the basement.
    However, correct me if I am wrong, but I was under the impression that in NJ you don't have to run BX cable in walls and ceilings, romex is allowed???
  • Serendipity
    BTW Sal, do you have any suggestion for my projector setup?
    See this thread: http://www.polkaudio.com/forums/showthread.php?t=63908
    I'm debating which projector to go with especially since I am using a 4:3 screen. Any advice would be greatly appreciated!
  • kuntasensei
    Lasareath wrote: »
    I just installed a Sanyo PLV-Z2000 at a client's office, It's a very nice projector, they were very happy with it. But I really did not test it out too long, they showed two 15 min DVD's and 2 slide shows and they were done.
    But, it is a nice Projector, I had some issues with the keystone but I think that maybe the projector is not high enough or the screen is not low enough. One day I may play with some settings but the client was happy.
    Below are pictures from my Install.
    Sal
    Nice install. Why would you have keystone issues though? If you level the projector (which it definitely doesn't appear to be in those pics) and use the lens shift to line it up to the screen, you shouldn't have any keystone issues at all, regardless of how high or low the projector and screen are.
    Equipment list:
    Emotiva XPA-3 amp
  • Serendipity
    I think he ran out of range with the lens shift and had to use a little bit of keystone adjustment to make the screen even.
    I too think the projector should be higher or the screen should be lower, as that would require less keystoning to get the picture to be square.
  • kuntasensei
    Sadly, the Z2000 doesn't have digital keystone adjustments (mostly because... well, you shouldn't need them). I find it hard to believe he ran out of range with the lens shift based on those pics. The Z2000 can shift almost 2 screen heights. As close as that screen is to the ceiling (which is about where mine rests), he should still have PLENTY of lens shift left.
    Equipment list:
    Emotiva XPA-3 amp
  • Serendipity
    Lasareath wrote: »
    I have no idea man, this is my 3rd projector install and the only one with a keystone issue.
    The previous two projectors had digital keystone adjustments and are perfectly square
    Did you run out of adjustment with the lens shift?
  • Serendipity
    Lasareath wrote: »
    I finished with the set up of the room an hour before their presentation, I just told the client that's way it's going to be. one person said It looks great!, One said it made it look like 3D and another said nobody is gonna even notice anything is off.
    I'm going back next week and I will play with it.
    Alex you wanna take a ride down?, they are in Englewood NJ
    Sal
    Sal,
    Sorry but I can't make it. I'm no longer in NYC, I'm living at school. So if we want to do another gathering (maybe at my place this time), it'll have to be either sometime in March or after I get out of school.
