Newbie help - Which budget Amp should I buy for RM6750?
sandix
I have purchased a RM6750 which was hooked to my Yamaha RX 361 Recevier. Need to replace the receiver. So I wanted to know what is the minimum power (watts per channel) I would need to drive the RM6750? Also what should be the max. so as to not blow out the speakers. Thanks in advance for your advice.
