A strange problem w/ two amps.
GoBlue
GoBlue Posts: 30
edited February 2008 in Car Audio & Electronics
Ive got two Alpine amps, a 4 channel, and a mono sub. I just hooked em both up and only the sub is going. I have used the 4 ch. before so I know it works. The 4 ch. is ON, but no sound. Can you destroy an amp by touching the ground and power together or sparking the power cords? I did that once or twice. I have narrowed it down to that, or not setting my head unit up right. Im pretty sure its all fine, I personally think there is an amp problem. Any ideas?
Deck: Pioneer deh-p6800mp
Theater:
Pioneer Elite VSX-55TXI
Adcom 555
Acoustic Research AR9 (Latest)
JBL S Center
Definitive Technologies ProCinema 1000 (Surround x2)
JBL PS1400 Sub
Monster 3600 MkII Conditioner
NAD T572 DVD
PS3
Lots of wire
-Looking for a decent Sunfire MK II-
Samsung LNT-4665F
Polk OMW3 - TV Speakers
Vintage:
Pioneer SX-780
Pioneer PLA-45D Turntable
Advent Heritage Speakers
Post edited by GoBlue on
  • exalted512
    exalted512 Posts: 10,734
    Youre either:
    Not getting signal to the amp
    Causes:
    Bad RCA
    Bad head unit output
    Head unit output is turned off
    RCAs came undone at amp or radio
    Amp not getting enough voltage/current:
    Causes:
    partially blown fuse
    pinched power wire
    Not getting signal from the amp:
    Causes:
    amp outputs are bad
    speaker wire cut/pinched
    terminals inside the box or at the subwoofer disconnected
    Bad sub
    To test:
    Since you have another amp, unhook the good amp and put the amp in question in its place. If it still doesnt work, thats 98% guaranteed its a bad amp.
    -Cody
  • GoBlue
    GoBlue Posts: 30
    I swapped out amps and found out that it doesnt work with the sub either, so how would a brand new amp go bad, but still turn on? Is it something that I did maybe?
    Theater:
    Adcom 555
    JBL S Center
    JBL PS1400 Sub
    NAD T572 DVD
    PS3
    Lots of wire
    Samsung LNT-4665F
    Vintage:
    Pioneer SX-780
  • exalted512
    Is there a fuse on the amp? Try replacing it. If it still doesnt work, its probably the amp.
    -Cody
  • ShinAce
    ShinAce Posts: 1,194
    Shorting the power wires should not damage the amp. Keep troubleshooting.
