2 subwoofers and now both stay on...
when i had 1 subwoofer, it will go into standby when system is off or no media is being play.
just added another one yesterday and now they wont go into standby
-each sub is connected parallel to the lsi15 at the output of the amp
-both switch left on auto
-both set to 60Hz on low pass dial
-both connected to the same surge protector
any input helps
TIA
any input helps
TIA
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612
Buttkicker
Post edited by SlowcarIX on
I had a similar problem, I stopped to stop using the auto on feature."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
when i turn the amp off, the 2 subs will go into standby in 15mins...problem is i leave the amp on...
it goes into standby when there was only 1 sub...connection is the same - but with 2, auto mode does not workmy 7.(1x4) HT setup
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
Are they run off a Y, or have their own outputs?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
the Y connection is made at the amp output - 1 pair of speaker wire going to the front speakers, 1 to the sub
my 7.(1x4) HT setup
Buttkicker
Have you tried using the LFE output from the processor?
I'm wondering why you would use speaker wire hookup, without thed front speakers attached to the sub? How is the crossover applied to the mains with this setup? -
I agree, go with the LFE connection."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
