SDA 1C and Bridged Rotel Amps Question...
Bullet21
I'm pretty much a newbie here and have a question. I have a pair of Rotel 980bx amps driving Magnepan IIIa's and right next to them I have a pair of 1C's and I'd like to toggle between the 2 (really just unplug the wires from the maggies then into the polks) - would it be a matter of just connecting the negative terminal on the amps and I'd be good??
Also i would like to buy the RD0194-1's for the Polks - is that just a matter of calling polk customer service??
Tim
Tim
Post edited by Bullet21 on
If the Rotels are run as mono bloc's then no you can't use them unless you have the option AI-1 inter connect cable. If the Rotels are normally stereo amps that can be switched to run mono then the likely hood of connecting the negative speaker terminals is low. Contact Rotel for further info concerning strapping the Rotels together.
Simply call Polk Customer Service and ask for the RD0194-1 replacement tweeters and tell them you are a Club member. Last time I checked they were $104 a pr/shipped 2 day FedEx. You need 2 pr. so plan on $208 if the cost is the same as in the past.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
plus the fact that I believe the 1C's are less than 8 ohms, might actually be 4 ohms, thus making running those amps at bridged mono dicey even without the significant negative ground issue.
I would just go with a solid no across the board on itLiving Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
Correct. My 1C manual says "Greater than 4 Ohm" but mine measure right at 4 Ohm without a load. I would 2nd the no across the board.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
You can't strap the negative posts together on bridged amps and when bridged they are rated for 8 ohm nominal loads only, so as Lou stated, that would be a solid no across the board.Political Correctness'.........defined
President of Club Polk -
I guess I'll just have to look for a good stereo amd to drive them.... Maybe an old SAE 2400L from the day!!
