Should I wait?
tibasnatch
I am getting my 2 rti8 speakers tomorrow and then on friday I will be getting my csi3 in the mail....should I wait and hooked them all up together or go ahead and hook up the rti8's first....just wondering if ill get more of a shock factor if i hook all 3 up and then listen?
thanks
thanks
Post edited by tibasnatch on
Do it all at once and be done, that way you can set them up together and have a listen. Either way you'll get the "WOW" factor.Shoot the jumper.....................BALLIN.............!!!!!
