SVS PB10-NSD or SVS SB12+
gollumis
hello all,
i am somewhat new at this, but i am starting to build a nice HT system. i was wondering for a 14 x 14 room which of these subs would work best. i am planning on getting the onkyo 705 or 805. Another question i have is about the cable hook up for the SB12+, how do you hook up a single subwoofer cable to this sub. I can see in the pictures that it has L and R inputs, the cable that i just purchased is a single cable, no L or R. Can i use this cable? i am planning on using the sub for movies and some music. Sorry if this has been posted before, i didn't see this posted so i thought i would ask.Thanks
Post edited by gollumis on
go for the PB12 plus/2 thats on sale and dont look back. Sub cable goes from Sub preout of the AVR(receiver) to input on either L or R on the sub. Some say using a splitter will give you a slight gain, so you can try it out if you want. Other than that you'll be fine. Welcome to the club.Shoot the jumper.....................BALLIN.............!!!!!
For a square shaped room, get the biggest sub you can afford/fit."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Cool, thanks for the replies.
i cant afford the PB12-plus/2, plus its to big, the wife would kill me. why do they make L and R when a lot of the subwoofers i have seen just have one input? My size constraints allow me to either get the 10-nsd or the pb12+ the smaller one(699) thanks -
Depending on the sub, you can just use the LFE in or get a Y splitter for the L&R channels."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Based on my experience, the PB10 would be the better choice for HT use due to its roughly 19hz tuning (if memory serves me correctly). I think the SB being a sealed design would be better used in a small room or as a killer 2 channel music sub.
I think you will be happy with either. I lean a little more towards the sb12 plus. Little higher quality driver. Smaller footprint (for wife reasons):). Might not get quite as low as the nsd10 but with the adjustments on the amp you should be quite happy. Just my 2 cents. Like I said, you will probably like either one.Silversmoky
would that noticebly sound different (the low i mean)? i thought that the 12, since it was bigger (and more expensive) would be an overall better sub. thanks for all the feedback.
In my opinion I would opt overall for the 12. It doesn't go quite as deep as the ported 10 but it will still get down there pretty well. I have a 10" sealed with a 500 watt amp and a ported 12 with 300 watt amp and I like my 10" a lot better. To me it is much more powerful sounding and it is really nice with home theater. Just my experience though:) Someone might say just the oposite. It is really up to you. Can't make a bad decision!Silversmoky
