Twin Cities Polkies
Windwalker
If one were to do some shopping on GW sites, they might find a pair of Monitor M7 that possibly could be had for less than 10 bills
Enjoy hunting...
Enjoy hunting...
Some of the worst wrongs get righted on three cords
Post edited by Windwalker on
Windwalker wrote: »If one were to do some shopping on GW sites, they might find a pair of Monitor M7 that possibly could be had for less than 10 bills
Enjoy hunting...
I'm sorry, but what are GW sites?
Regards,
Treker -
GW is a second hand store
If your airport is MSP and you need me to run this through my decoder ring, PM me. Egnima machine is working as wellSome of the worst wrongs get righted on three cords -
Windwalker wrote: »GW is a second hand store
Thanks! I'll PM you for the decoding work.
Later,
Treker -
Treker-1701 wrote: »Thanks! I'll PM you for the decoding work.
Later,
Treker
The system says I need a minimum of 10 posts in order to PM someone. This one makes 10! Yahoo!
Treker -
Hi All,
Thanks to a lead from Windwalker, I scored a great set of Polk M7's at a local thrift store here in Minneapolis. Less than $30.00 for the set including tax! What a deal!
All the drivers work and the cases are in pretty good shape with damage to just one rear corner of one speaker. Of course the bottoms are a bit scratched up, but that is to be expected. The frame of one of the speaker grills also had a broken spot in it, but I think that I should be able to fix it. I'm working on it right now.
Here are a few pics for your review.
Later,
Jay B.
