Need help with my onkyo receiver
tibasnatch
tibasnatch Posts: 30
edited February 2008 in Electronics
I got the one that came with the sr-800 HTIB the one u can buy right now for $500.....and I have everything adjusted all funky...is there a way to reset it to all defaults like it was when I bought it new?
Do you need to "SET-UP" a receiver or are they pretty much good to go out of the box...i heard a few years ago there is some tweaking o get the best sound??
thanks
Post edited by tibasnatch on
  • Sherardp
    Sherardp Posts: 8,038
    yes you have to tweak, use the manual for guidance on returning settings to default, it should be in there some where. As for tweaking, etc. you can use the test tones that the receiver offers to setup speaker distance, speaker size, etc. Most here will set the speakers to small, crossover set 60hz or 80hz depending on your liking. If you'd like to tweak even further, I'd suggest a radioshack SPL meter to dial everything in precisely.
    http://www.audioholics.com/tweaks/speaker-setup-guidelines/
  • tibasnatch
    This onkyo reciever actually comes with the (forgot what its called) thing that plugs into the phono port and u set it in the middle of room and it send outs test tones from each speaker and it adjust the setting in the rceiver.....is that pretty much all I need to do or is there more tweaking that can be done?
  • margate21
    margate21 Posts: 105
    do u mean microphone? do u own a tripod? if so u can use it with the mic to get to ear level measurements. the audessy set up is very easy to use.
    lsi 15's, lsi c, lsi f/x
    onkyo 805
    sunfire tga 5200
    toshiba - xa2
    panasonic bd30
    sony kdl40v2500
    svs sb12+
  • edossin4
    edossin4 Posts: 105
    I just used that audessy set up. It is really easy to use and the sound is great.
    Onkyo Tx sr805
    Oppo Dv-981hd
    Onkyo Dv cp704
    Adcom Gfa 555
    Adcom Gfa 545
    Polk Audio rti 12
    Polk Audio cs400i
    Polk Audio fx300i
    Panasonic 54" rear projection
    Direct HDTV DVR
    PS3
