mm6 in a maxima?
Systems
Anybody fit so mm6 components in 95-99 maxima? Kim informed me that the cut out diameter of the mm6's might be too big, so i'm wondering if anybdoy did it and how they did it.
thanks,
mike
thanks,
mike
Testing
Testing
Testing
Testing
Testing
the mm6 components are like 6 3/4 diameter if i'm not wrong -- either way they're an "oversized" six... basically there is a "standard" size for 6 inch round speakers... like 6 1/4 or something... and the momo's are a little bigger... so u just get a jig saw and cut the hole out to the right size -- just trim a hair off it all the way around -- measure to be sure of course before u do anything -- and be sure the speaker is not too deep.The Artist formerly known as PoweredByDodge
